Some of the legacy computer stuff just isn't supported on the newer operating systems. It's infuriating that the companies do not do this, especially when you purchased an expensive piece of hardware, but the reality is they can't support their gear forever.
To put the bt-35k2 headset in pairing mode, press the ON button but hold it down for about 6 seconds. Once detected, you'll be prompted for passkey; then use 0000. Pairing will complete once authenticated.
Put the bt-35k2 headset in pairing mode.
(Press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
2. Put the bt-35k2 headset in pairing mode (press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
3. Once device detects headset, you'll be prompted for passkey; enter 0000.
If you can get the headset into pairing mode, and your phone into detection mode and it's still not pairing, try removing the battery while powered on. Replace the battery and retry, and it should work.
The pairing code is 0000. Turn off your BT-01 then back on again. The blue light flashes quickly. Only during that time can you pair with it. Good luck, Andy W
To put the bt-35k2 headset in pairing mode, press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode. Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
