Question about Toshiba 32AF42 32" TV
I HAVE A TOSHIBA REAR PROJECTION AND IT WILL TURN ON AND OFF 4-10 TIMES BEFORE A PICTURE COMES ON. THE SOUND IS ON SOON AS THE POWER IS TURNED ON.....
    Sergeant:
    Champion:
  • 431 Answers
Toshiba bs usually have bad voltage regulator ic's also bad caps in pwr supply and conn. on flyback
Posted on Jun 01, 2010
SOURCE:
When I turn on the TV the sound comes on but there is no picture. It turns off/on automatically several times then the green and red lights blink with no sound.
this is common problem for rear projection TV set's you have to replace the BULB after a approx. time of 2 years I found the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=52HM84
Sep 17, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 50hx81 no picture or sound
If you managed to find a manual or have resolved the problem, please post it back here to benefit others. You probably had a partial or complete power supply failure.
Thanks-
Dec 16, 2008 | Toshiba 50HX81 50" Rear Projection...
Have a Toshiba 42H82 rear projection TV
Sounds like a power supply problem. You will need your tech again.
Nov 13, 2008 | Toshiba 42H82 42" Rear Projection...
Panasonic PT-61HX42F turns on, but wont stay on.
you need to change the stk 392-110 (2 ic ) and some resistor around the area ok
Sep 08, 2008 | Panasonic PT-61HX42 61" Rear Projection...
Toshiba TP50H95 No sound no picture
Sounds like a problem in the deflection circuits either vertical or horizontal. You may also want to check the solder connections in the tuner as they have been known to develop cracks over time. But the prior shrinking tends to say deflection problems.If I can assist you further please let me know.
Feb 03, 2008 | Toshiba 50H81 50" Rear Projection...
TOSHIBA 40H80 projection TV - no sound / no picture
it could be, that would be the first thing i would do to rule out I would first check for loose connections on the board.
Dec 06, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba Power on and off problem
sounds like the convergance IC might be bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
at least it would be the first thing to replace.
Nov 17, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 32AF42 32" TV Logo
49 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
