Ricoh Aficio AP410N Laser Printer Logo
Anonymous Posted on Jun 01, 2010
Ricoh Aficio AP410N -error code SC514.
Hello, We have a Ricoh Aficio AP410N Laser printer.
It stoped working and gives the error code SC514.
Resetting it didn't help.
Could you please advise?
Many thanks
  • Anonymous Jun 01, 2010
    The printer doesn't do anything at all any more. It just gives me an Error code: SC514.
    Any idea? Thanks in advance
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1860
Points
16
Please explain ur problem
I do not know how may I repair error sc 546 in ricoh aficio ap410n
fuser problem, push in order clear modes (yellow button) 1 0 7 and hold the red stop button for 5 seconds the screen will change, turn off copier red power switch and turn back on if problem comes right back you need a service call
Ricoh aficio ap410n sc 541 power off on
SC451 Paper transfer belt motor lock error. Needs replacement,
2helpful
Need to reset maintenance count on a richo aficio AP410n laser printer ?
• After the technician replaces the fusing unit, the maintenance counter must be reset with engine SP mode 7-804. • 7-804-1: Transfer roller • 7-804-2: Paper feed roller • 7-804-3: Fusing unit).
1helpful
Hello, We have a Ricoh Aficio AP410N Laser printer. It stoped working and gives the error code SC514. Resetting it didn't help. Could you please advise? Many thanks
There is no SC514 on an AP410N. Do you mean SC541? SC541 is a fuser code that a technician has to reset. It could be something as simple as a power spike, or it could be a dirty sensor or a blown board.
I have a Ricoh Aficio AP410N printer and it displays a message that says "remove misfeed internal path" error message. I checked the paper path and there is nothing there. I checked the manual and there...
Did you take out the toner cartridge and paper trays and open all the covers to try to find the misfeed? If there is really nothing there, you can try turning the printer off and back on to see if it clears itself.
1helpful
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
9helpful
Error Code of SC545
That code will not reset by powering off and on. It needs to be reset in the service mode.
Error code
Thats not good. Its a laser problem. You are probably going to need a service call.
5helpful
Ricoh aficio ap410n printer, Replace Maintenance Kit
unbelievable... you guys charge for discussion??!!! get real! i'll find one of about 1,000 free places where i can discuss this and find an answer....
puleeze
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
