Question about Toshiba 46HM95 46" HDTV
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an oscilloscope. what do i check?
  • Toshiba Master
  • 8,457 Answers
First power on to tv.Check all the three indication front LED lights.The power,Fan temp,projection Lamp LEDs.If the Fan temp or the Lamp LEDs lights on or flashes.The projection lamp life is over,need a new projection lamp.After replaced the projection lamp,power on u hear alot of clickings,that mean the Ballast board is dead,this board help to ignite the projection lamp.Replaced the Ballast board.Ur tv should work now.
Posted on Jul 10, 2010
  • Toshiba Master
  • 1,527 Answers
Hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
Posted on Jun 04, 2010
SOURCE:
I have a Toshiba DLP Projection Television 46HM95 and one of the fans stays on all the time can't find any data on the televison
The fan on the digital board is MEANT to run 7/24 as that board is powered and up all the time, that is normal.
Nov 02, 2012 | Toshiba Televison & Video
I have a Toshiba 46HM95 TV that sounds like a lawn mower when you start it up...this just started and it sounds like its coming from the cooling fan...is that possible and can I fix it myself?
Yes,have a philip screw driver,just take the back cover off.Find the fan,unscrew like four screws,disconect the input connector.Should take out the fan out easily,replace it.Tries websites like Partstore.com,Ebay.com to buy a new fan.
Sep 14, 2010 | Toshiba 46HM95 46" HDTV
Humming noise in Toshiba television
my 46HM95 was humming also, I have the extended warranty and the company came out and diagnosed it as the light engine. the part was backordered and it was just fixed today, it was ordered back in February. Problem was solved.
Aug 12, 2008 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95 White triangle shadow
I have the same problem with my television i was told it needs a light engine the cheapest one around is $500.00 and that does not include the cost of repairing it. All I have to say is enought people write into toshiba with this complant if enough people write maybe we can get them to replace it for us.
Aug 09, 2008 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95 Buzzing
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Apr 02, 2008 | Toshiba 46HM95 46" HDTV
Toshiba dlp
The light engine part number is 234054 and cost $456.00
Dec 20, 2007 | Toshiba 46HM95 46" HDTV
Still dark after replacing lamp
possible ballast problem or cooling fans not operating
Oct 13, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95 46 tv
If the line is all that is showing with black on the top and bottom. This indicates a loss of vertical deflection which is caused by the loss of the veritcal sweepignal. Check the output of the vertical section of the TV set. You will need an oscilloscope, and multimeter along with a schematic.
Oct 01, 2007 | Toshiba 46HM95 46" HDTV
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95 46" HDTV Logo
397 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
