Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Posted on Jun 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My oven does not bake any more
When i turn my oven on to bake something, it heats up for about 5 minutes then it quits getting any hotter. Broil still works, it just wont bake. Help would be appriciated!
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Jun 01, 2010
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10842388
Points
101584
If your electricMy oven does not bake any more - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
  • Reannabee77 Jan 22, 2012
    Hi, I replaced the heating element in my electric oven and it worked for a couple weeks and it quit baking again. Do you know why this might be happening?
1helpful
Built-in electric oven jtp15w2ww gets to temperature then quits. No error codes.
If your built-in electric oven is getting to temperature and then quitting during a bake cycle, and the upper heating element is not working during the bake cycle but works on the broil setting, it is possible that the problem is with the bake element. Here are some troubleshooting steps you can take:
  1. Check the bake element: The bake element is the heating element located at the bottom of the oven. To check if the bake element is working properly, turn on the oven and set it to bake mode. Open the oven door and look at the bake element. It should be glowing red. If it is not, then the bake element is likely faulty and needs to be replaced.
  2. Check the oven temperature sensor: The oven temperature sensor is a small probe that is located inside the oven. Its job is to monitor the temperature inside the oven and communicate that information to the oven's control board. If the sensor is faulty, it may cause the oven to shut off prematurely. You can test the sensor with a multimeter to see if it is working properly. If it is not, then it needs to be replaced.
  3. Check the oven control board: If both the bake element and the oven temperature sensor are working properly, then the problem may be with the oven's control board. The control board is responsible for controlling the oven's heating elements and other functions. If it is faulty, it may be shutting off the oven prematurely. In this case, the control board will need to be replaced.
It is recommended to hire a qualified technician to perform these tests and replace any faulty parts to avoid any risks of electrical shock or damage to the oven.
Nov 23, 2022 • Ovens
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
1helpful
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
I have a Samsung electric range FTQ352IWUX, and neither oven functions (bake nor broil) produce any heat.
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
1helpful
My oven will not heat up to temperature
It may be the bake element that has gone out. The self clean usually uses the broil element to heat the oven. And most oven will either put 120 volts to the broil element while baking or pulse the broil element while baking. This will cause the oven to get warm but not hot. Check the oven bake element it cound be bad or a wire may have burned off.
Feb 14, 2014 • Ovens
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 • Ovens
1helpful
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
2answers
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 • Ovens
I can't get oven to work on broil or bake; only self-cleaning.
Hello
Welcome to Fixya
My name is Huum,
Try turning the breaker off for 5 minutes and see if this resets the system.
if not you may have a defective Control board and you will need to have a HANDS on tech to diagnose these parts to be sure! They will have the diagnose equipment !
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
