The front display is no longer working it's the area that shows that it is on and the time. Since we've purchase our Bosch dishwasher we've used it no more than 10 times.
You need a service call and an engineer with a laptop.
Bosch dishwasher error code e 01
If a Bosch dishwasher displays the error code e01, it means the control panel is malfunctioning. ... If the dishwasher does not work at all or fails, the faulty control board is probably the case. It controls all the functions.
I got answer from previous post on your site by 'boeschbrady'.Person had same problem,also said part was under Warranty. we called the store where unit was purchased and my unit is also under Warranty "less than 5 years old' repair man is coming next week.Thank you for a great site Patee
UNfortunately that sounds like the controle module and you can not have that fixed. only replacement of the part will fix that problem
HERE you can find the drawing and parts. You can also order them here
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied! Did you try to use the extra Dry setting? Did the dishwasher work before this or is it brand new? What is the model number and year? Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat With this option you can raise the temperature of the rinse water and increase the drying time which will result in improved drying. To activate : Press and hold the left cancel drain button , Then press and hold the on/off button when the LED display shows a, "00" or a "01" To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01" To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00" press the on/off button to save the settings.
