If you're dying to try out Windows 7 but aren't ready to give up your
installation of XP or Vista, let's take a look at how to dual boot
Windows 7 with XP or Vista.
Assuming you've already downloaded a fresh copy of Windows 7, you'll
need to burn it to a DVD in order to do a fresh installation. To handle
this task, grab a copy of the
most popular CD and DVD burning tool ImgBurn, burn the ISO to a DVD, and move right along to step 1.
Step 1: Partition Your Hard Drive
Before you go installing Windows 7, the first thing you need to do
is create a new partition on your hard drive to hold the new
installation of Windows. Partitioning your hard drive will vary
depending on whether you're running XP or Vista—namely because Vista
has a partition tool baked in, XP does not.
Partition Your Hard Drive in XP
To partition your hard drive in Windows XP, you'll need to download
some sort of third-party partitioning software. There are a lot of
options available, but I prefer to stick with the
previously mentioned GParted live CD, a free, open source boot CD that can handle all kinds of partitioning duties.
To use it, just download the
GParted Live CD,
burn it to a CD, then reboot your computer (booting from the disc).
You'll boot right into the partitioning tool. HowtoForge's previous
guide to modifying partitions with GParted is a great place to start, but it's a fairly basic procedure:
- Resize your current OS drive to free up enough space for a Windows 7 partition (the minimum system requirements ask for 16GB).
- Create a new partition from the newly freed space.
- Apply your changes.
Partition Your Hard Drive in Vista
The folks at Redmond were kind enough to include a disk partitioning
tool in Vista if you know where to look. So go to Control Panel ->
System and Maintainence (skip this one if you're in Classic view) ->
Administrative Tools -> Computer Management. Once you launch the
Computer Management tool, click on Disk Management under the Storage
heading in the sidebar. It's partitioning time.
Luckily we've already gone down this road before in step-by-step detail, complete with pictures, so check out our previous
guide to creating a new partition in Vista. In a nutshell, you'll need to shrink your current OS partition to free up at least 16GB of disk space (per the
Windows 7 minimum system requirements), then create a "New Simple Volume" from the free space.
Step 2: Install Windows 7
Now that you've done all the heavy lifting, it's time for the easy
part: Installing Windows 7 on your new partition. So insert your
Windows 7 disc and reboot your computer (you'll need to have enabled
booting from your DVD drive in your system BIOS, but most PCs will have
this enabled by default).
Once the DVD boots up it's a simple matter of following along with
the fairly simple installation wizard. When you're choosing
installation type, be sure to select Custom (advanced) and choose the
partition you set up above. (Be careful here. Choosing the wrong
partition could mean wiping your other Windows installation altogether,
so make sure you pick the new partition you just created.)
After you select the partition, go grab yourself a drink and let the
installer do its work. Windows will run through some installation bits,
restart a few times in the process. Eventually you'll be prompted to
set up your account, enter your license key, and set up Windows. Keep
your eyes open for fun new Windows 7 features, like your new homegroup
(and the accompanying password). When it's finished, you're up and
rolling with your new Windows 7 installation.
Congratulations! You should now have a new entry for Windows 7 on your
boot screen when you first start up your computer. You've now got all
the tools necessary to dual-boot Windows 7 and XP or Vista—or even to
triple-boot Windows 7, Vista, and XP.
Thanks for the reply Lolita, I tried downloading the trial version of Partition Magic, but it would not download for some reason, will try later. Elslicko
