HP DeskJet 5550 InkJet Printer Logo
Posted on May 31, 2010
HELP PLEASE HP deskjet 5650: ink light keeps flashing and does not print. Printer paper and cartridge is all brand new but yet it does not print. ANY SOLUTIONS PLEASE =\ THANKING YOU
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on May 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
4593
Points
37
Remove one cartridge and close the access door. If the cartridge light goes off, the bad cartridge has been removed. If the light continues to blink, remove the other cartridge and reinstall the first one. If the light goes off, the cartridge in the printer is the good one.
Top light blinking, will not print
I believe that the top light is the low printer cartridge signal. Did you replace the cartridge or just take it out and reinstall it? Did you use a new HP cartridge or refilled cartridge?
Try a new ink cartridge from HP and double check that you have the correct cartridge for your printer. If that doesn't solve the problem, contact HP.
1helpful
2answers
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
2helpful
Out of paper light flashes even after paper is loaded
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
No paper light ligted even after paper is loaded
4. paper jammed
Hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
HP DESKJET 5650 - DOES NOT PRINT ON ANY PAPER
Hi dear; When you put in the new cartridge ,did you removed the plastic seal(tape)?
1helpful
2answers
HP Problem
I had same trouble, you need new ink cartridges.
3answers
Hp deskjet 5650 inkjet printer
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
k24674
Grand Canyon Tech
Grand Canyon Tech
