Question about HTC G1
Safe mode on g1 wont go away
I can not remove and get out of safe mode on my g1
    New Friend:
Help me turn off safe mode on my android please for free
Posted on Apr 19, 2014
Press the red phone button and choose turn off then press ok when the next window comes up and the phone will shut down.try and turn it back on wait for it to load up and you should be good to go
Posted on May 31, 2010
  • Reese Antee
    Reese Antee Apr 19, 2014
    i have a android tablet and i want to turn off safe mode
SOURCE:
Hi, just bought a htc phone and want to put the pic's i've taken with my phone on my computer. How do i do that?
Hi dforte1145,
  • Connect your G1 to your computer via USB
  • Pull down the notification menu and select "USB connected: Select to copy files to/from your computer."
  • "Turn on USB storage"
  • Now open your phone in a folder on your computer
  • You will see a folder that says "DCIM" (This is where your pictures are stored)
  • Open DCIM and view the pictures in the folder "Camera"
  • Drag the photos you want to copy into the "Camera" folder
  • Safely remove your G1 from your computer (Windows: "Safely remove hardware" OSX: Drag G1 icon into the trash bin Linux: Unmount)
Now open the "Gallery" application on your phone all all of your photos should be there!
Feb 16, 2011 | HTC G1
The safe mode is on how do I remove it
Using the safe mode feature on your T-Mobile G1 will allow you to easily pin point an issue you are experiencing with the device. Follow these steps to enable and disable the safe mode feature.
  1. HOW TO TAKE YOUR T-MOBILE G1 OUT OF SAFE MODE
    If you have found yourself in safe mode and don't know how to turn it off, or if you are finished troubleshooting, turn your device off as you usually would. When you restart the T-Mobile G1 should not be in safe mode anymore.
  2. If the T-Mobile G1 is still in safe mode when you restart, there is something else wrong with your device. At this point you will need to contact technical support to assist in diagnosing the issue.
Nov 14, 2009 | HTC G1
Blue light on top of g1
I solved this problem by booting into SAFE MODE on the G1:
Press Menu Button and Switch on the G1 Phone using Power button. (Do not release menu Key).
That Got it to turn on. but upon power down it did the same thing with blue light. So I always start in SAFE MODE. I will start uninstalling programs until i find out which one is causing problem.
Sep 11, 2009 | HTC G1
Safe mode
Well I don't know if this will help your G1 but it did to mine. 1st If your charging it disconnect it 2nd Open your back cover and take out the battery 3rd Hold the power button (the red one obviously) for 15 seconds 4th Once your done with that replace the battery and cover Once you turn your phone on it should be out of safe mode otherwise call tmobile or whatever service provider you have they should help or call the android People. Hope this solved your problom.
Aug 11, 2009 | HTC G1 Smartphone
My g1 has safe mode on the botton of the left corner
I just had the same problem. I had turned on my phone in the usual way and once it loaded I noticed it was in safe mode. This was not something I had told the phone to do. 1st I unplugged the phone from the charger. 2nd I removed the back cover and the battery. 3rd I held down the power key for 15 seconds. 4th I reinstalled the battery and back cover. And finally I turned the phone back on. NOTE: my phone started up and then restarted itself as soon as it was done loading. Now everything appears to be working correctly and efficiently.
Jul 18, 2009 | HTC G1 Smartphone
When i switch my asus G1 laptop on it brings up a webpage giving me two options 1) launch startup repair 2) start windows normally the problem is that whatever option i press it comes back onto the same...
Try booting into SAFE MODE by pressing F8 after you turn on computer and before Windows logo appears. If you are able to start Windows in safe mode, you may be able to ROLL BACK your system to an earlier date. In the START menu search box, type RESTORE. This should bring up the SYSTEM RESTORE menu. Choose the RECOMMENDED RESTORE option first and see if that fixes the problem. If not, go back and select CHOOSE DIFFERENT RESTORE POINT and select an earlier date.
Jun 17, 2009 | ASUS G1 Notebook
Trouble shooting my GR- DF550 vidio camera
mine is in safe mode 3 too and it won't go away. It's over a year old and not worth $$$ to fix. It's time to move up to a HD hard drive video. I suggest you too.
Jan 20, 2009 | JVC GR-DF550 Mini DV Digital Camcorder
G1 safe mode
Power the device off, while it is off press and hold the Menu button and the Red Power Button at the same time, when the phones boots back up the Safe Mode should be off. If this does not work a Master Reset may be required.
Dec 27, 2008 | HTC G1
PLEASE HELP! my tmobile G1 has been acting strange all day since I turned on phone. The phone went into safe mode now I have I'm in the bootup and it tells me to press home and back to reboot, and it wont...
so when your phone boots up in safe mode, it will only give you the ability to menus without any connection to wireless networks. you wont be able to view any apps or surf the web....
to fix this turn off the device and while its off, press and hold MENU and RED keys at the same time until you see the home screen
if that doesnt work, try to reset the device. i think thats what you were previously trying.....
when the handset is off, press HOME and POWER KEYS at the same time until a triangle with yellow "!" appears. release keys and slide open the keypad. press "ALT" and "W" at the same time until phone reboots. attempt to log in again.
good luck! :)
Dec 10, 2008 | HTC G1
HTC G1 Logo
873 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
