SOURCE: Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
SOURCE: My washer will not spin off the water
Just looked at mine the belt is broken.
You have to remove the motor and take the pump off to replace it.
28 1/4" x 1/2" Belt
SOURCE: I have a Maytag Legacy gas dryer that won't heat
OK, Crispy... the con census is that the coils have failed. The coil kit you'll need is part number 279834 and can be either purchased on line or at your local appliance parts retailer.
{{{UNPLUG THE DRYER BEFORE PROCEEDING!}}}
The repair is easy, remove the lower service access panel by removing the two screws located on either side at the very bottom. Then rotate the panel toward you and pull it out.
At the bottom right, you'll see the gas valve. There are 2 round, black coils mounted to it. One of these has 3 wires going to it and the other has 2 wires. You'll also see that they are held down by a brass colored bracket. Remove the wires from the coils and then remove the brass colored bracket with a stubby (short) Phillips screwdriver. NOTE THE POSITION OF THE COILS AND NOTE WHERE THE WIRES GO!
Install the new coils and bracket them down. Install the wires to the coils. Now rebuild the unit.
Easy breezy. Even if you've never done this, you're looking at MAYBE an hour... maybe.
Hope this helps,
SG
SOURCE: Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
