There really isn't much else to say about the problem except that all the buttons work properly but when you turn any or all the knobs, the burners do not even get warm. the oven does not work either.
It sounds like you may be missing part of the input voltage at the wall receptacle. You should be reading 220-240VAC across the two hot terminals (left and right slots) on an ELECTRIC range. Some homes are wired with two separate breakers to make up the 220 service that feeds your appliance. If this is the case, make sure one of the breakers is not tripped.
Or, you may have a possible bad power cord. With the unit unplugged, check the continuity of the power cord from end to end to make sure the wires are not broken.
The clock assembly functions off of a 110-120VAC source which is tapped off the input voltage. All the elements (including the oven) all use 220. If one of the input legs is missing, the clock will still function, but none of the elements will work. Please check and get back to me if this isn't the problem. I hope this helps you.
