Question about Hotpoint Freezers
Hi , i have a hotpoint quadrio fridge freezer which has developed a fault which is a design fault...the wire inside the door has been severed by the hinge making it very dangerous, having looked on forums it is apparent that many people are having the same probled,,..are hotpoint liable to repair it?...the unit's around 18 months old
    Top Expert:
  • Hotpoint Master
  • 6,289 Answers
Check with Hotpoint / GE and inform them of your concerns.
Posted on Nov 07, 2017
SOURCE:
  • 1462 Answers
SOURCE: Fitting a Zanussi fridge thermostat
the stat is clamped to the backplate of the frodge with a simple clamp held just by two screws. undo the clamp. the stat capiliary may be bent back on itself, if so straighten it and it will pull out
Posted on Oct 18, 2008
  • 16 Answers
SOURCE: Hotpoint FFA97 freezer works but fridge does not
It seems to me that there is a leak of gas from your unit.This is if you have 1 compressor/motor)If there is two compressors on unit then it can be thermostat for fridge.Anyhow check if motor is running all the time and is wery hot, if it is there is to little gas in system .This should be covered by guarantee.Jan
Posted on Feb 15, 2009
  • 3 Answers
SOURCE: Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Posted on Feb 27, 2009
SOURCE: my hotpoint ff187e fridge/freezer keeps bleeping and flashing
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Posted on May 09, 2009
  • 1531 Answers
SOURCE: Frost forming on top of inside door by hinge
try covering the hose in the bottom of the door with tape or remove the plugs and glue them shut.also the diffuser plate in the back of the freezer should be changed if you can not change it cover those holes with some aluminum tape.the insulation in the door panel should aslo be replaced there is a chance of ice built up in the door liner
Posted on Sep 17, 2009
Hotpoint quadrio fridgefreezer keeps tripping the electrics when I open the fridge door.
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring).
Dado
Apr 26, 2014 | Zanussi Freezers
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
My hotpoint ff187 fridge/freezer is making a beeping sound and has flashing lights. We have tried everything from turning off this button and that, then trying the power off and backwards again. There is...
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
Feb 09, 2018 | Hotpoint Freezers
Freezer not working
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 17, 2010 | Freezers
Hello, my hotpoint FF187E fridge freezer keeps tripping my electric off, sometimes it will stay on for a couple of days other times it does this straight away, any idears would be appreciated, thanks...
you may have a burned wiring which when wet trips off you electricity. the location may be in front of your unit between the doors if you have a two door fridge. if you have a singole door unit it may be located on lower area of the fridge body which where the water flow down when you have excess water dripping infront of your fridge. those two location are most likely because the wiring installations from thermostat, heater, and ligth are there. ofcourse you have to check first the compressor and it's auxillaries
Jan 13, 2010 | Freezers
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Feb 24, 2009 | Hotpoint Freezers
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Fridge freezer
fully defrost it 48 hrs with the doors open and that can often cure it.
Feb 11, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
249 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
