Digital channels drop out, then the signal strength reports as bad, therefore unable to auto program. Or manual program. No aerial problem, our other digital tv is fine. We have recently replaced the mainboard, reprogrammed it and the channels were present for about 5 days, then a re-occurance of the problem.
SOURCE: tv has no signal
sounds like the EDID data has been corrupted in your main board. it can be reprogrammed but most techs will just replace the board. either way someone will have to come out and look at it. it should have a 2 year parts and labor warr on it. call LG cust service and get someone out there.
SOURCE: 42LC2DR
You need to press the button on the top right of the control ( the TV button) once and that will allow you to control the tv once again. Problem occurs when you accidently push VCR or DVD button which means remote control will try a different frequency to operate a VCR or DVD that isn't there. Hope this helps.
SOURCE: KEEPS SAYNG NOT PROGRAMMED TO WATCH NORMAL CHANNELS
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
