Neff B1641 Single circotherm super Electric Oven Logo
Posted on Apr 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Temp display shows 444
There is no heat from either the oven or the grill. When the oven or grill is turned on the red heat light comes on but no heat. Also 444 comes up in the temperature display (not all the time) as though this is some sort of error code - maybe the thermostat is short circuit
mika
Level 3:
Master:
  • Master 469 Answers
  • Posted on Nov 20, 2016
mika
Master
Level 3:
Master:
Answers
469
Questions
0
Helped
224933
Points
2864
All the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again.If you want to get one,please refer to:
AmanStino 3 USB ports Car charger with 1 Type port AmanStino
DRICS
Level 1:
New Friend:
  • Contributor 1 Answer
DRICS
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
803
Points
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
5 Related Answers
Anonymous
  • Posted on Oct 30, 2006
SOURCE: oven doesn't reach temperature
Found this link on another site. I've placed an order for the element. Will let you know how I get on. http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=10044
Anonymous
  • Posted on Aug 18, 2007
SOURCE: Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
Anonymous
  • 25 Answers
  • Posted on Feb 04, 2009
SOURCE: Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Anonymous
  • 67 Answers
  • Posted on Jun 11, 2009
SOURCE: Intermittent tripping of circuit as oven just reaches temp
Sounds like the oven element is cracked and absorbing moisture when the oven cools down thus causing it to trip. Should buy a new element. there are hundreds of suppliers on the internet.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Oct 10, 2009
SOURCE: main oven fan is working. red light showing but
If the fan is working o/k, then you need to fit a new oven element, located at rear of oven behind removable cover.
Please rate my solution.
Thanks.
Smeg linear oven is displaying sho (showroom mode) and will not heat up. I have held down function knob for 5 seconds which clears SHO from display but within seconds it comes back. Any ideas
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
1helpful
Top oven temp display shows 4444
Control panel needs to be replaced. It may also be an error code for the repairman.
2answers
Oven wont heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Smeg oven UK80MFX1 troubleshooting
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Nov 30, 2011 • Smeg Ovens
Opening oven door trips rcd when up to temp. doesnt do it when cold
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
1helpful
2answers
Burnt some food yest in grill and is not working today. wouldnt turn on straight away so i left it till this morning but still not heating up. oven is working perfectly fine. could the heating element for...
if the temp light or indicator light for the grill is on then i'm tempted to say that it is the element but checking for resistance is the only sure way to know..
1helpful
Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
Nov 28, 2009 • Ovens
2helpful
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
2answers
Zanussi zbf 760 (9 yrs old now)
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
