Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
Posted on Feb 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Low water pressure coming out of faucet. good press at ang stop.
Low pressure coming out of faucet. great pressure coming off angle stops and through supply hoses. Is there an internal filter. I already removed the filter at the tip of the faucet. spray hose seems to spray at decent pressure. almost to a trickle out of faucet.
  • Jonathan Hardin
    Jonathan Hardin May 31, 2010
    How old is the faucet?
artie g
Level 3:
  • Master 873 Answers
  • Posted on Feb 18, 2018
artie g
Master
Level 3:
Answers
873
Questions
0
Helped
245730
Points
2752
If you just installed it check to see if it has a water saving feature that in some homes and almost restrict all the water force
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
  • Posted on Dec 05, 2008
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Anonymous
  • 92 Answers
  • Posted on May 04, 2009
SOURCE: New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
vacwater
  • 175 Answers
  • Posted on Nov 20, 2009
SOURCE: Sulfur smell from the Delta faucet
Your incoming water from the well is contamiated. A delta faucet will combine oxygen with the water and make the sulfer smell come out. It could also be iron bacteria causing the smell. Look in the back of your toilet tank and see if your have reddish or black stringy algae looking stuff growing in there. If you do, you have iron bacteria and it will smell.
Anonymous
  • 35 Answers
  • Posted on Feb 23, 2010
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Anonymous
  • Posted on Jun 26, 2010
SOURCE: My kohler k-12177 fairfax faucet is leaking when
How do I take my faucet apart , I have a leak when I change it back and forth between spray and stream ?
2helpful
Low water (hot and old) pressure in kitchen
Following link has troubleshoot walk-thru:
http://waterheatertimer.org/Low-water-pressure.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 30, 2017 • Plumbing
Faucet whistles
According to FixYa.com: "
This is most likely debris in the aerator, filter screen or check valve in the hand sprayer of the faucet. Try removing the hand sprayer and checking the filter screen at the end of the hose. The try removing the check valve to ensure it is clear of debris. It is the yellow ring with the white plastic flap in the middle. You can simply push in on the white flap and hook the yellow ring with a cork screw. Then pull it straight out. You may want to cover the drain with a dish cloth while doing this to keep small parts from being lost.
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
It could be one of two problems, one simple, one serious.
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Jan 08, 2014 • Home
Installed new delta leland 978 kitchen faucet. Water pressure from faucet is low. Cleaned screen and there was no change.Could there be a clog some where else in faucet system?
check the angle stop under sink as sometimes the washer gets lodged in the orifice to stop..make sure water is off to house before removing handle to stop...check the hose...then the stem and seat to faucet itself.
2helpful
Hello, I replaced the seats and springs in my faucet Delta Leland 2578 and now my water pressure is low. So I thought it was the stem unit assembly because it had a lot of deposits on it so I replaced...
it would only be aerator if hot and cold were low..what happened is when u shut angle stop off on hot water to replace assmbly..the washer on angle stop separated and is blocking the supply
Very low sprayer head flow
You can help to isolate the problem by checking the flow through the angle stops under the sink. Best way to do this is to first have flexible hoses, most likely 3/8" by 1/2". These flexible hoses can easily replace rigid piping from the angle stops to the sink. Turn the angle stops off, then unscrew the hoses/piping from the under the faucet. Aim hose into bucket and turn angle stop back on. If flow is still strong, then replace faucet. If flow is weak, call a plumber.
Well water comes out brown, low pressure
picking up sediment[silt-mud-dirt] holding tank probably bottom filled with it turn off well and flush out holding and hot water tank if one and install inline filter after holding tank to stop any further debris getting into water lines your pump is sucking the silt up from the well usually happens to places that have had really bad rain season or flooding
Oct 03, 2009 • Plumbing
2answers
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
4helpful
2answers
Low pressure and flow on hot water side of single handle faucet
  • Easy fix
  • Complex fix
Top Price Pfister Plumbing Experts
john h
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
