Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No picture Monitor comes on (picture appears) for a split second then picture goes away. Monitor stays on (green light remains on).
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on May 31, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368495
Points
33650
Power supply section will be the first place to check, find out if you do hav 12~18vdc feeding the inverter circuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
1helpful
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
1helpful
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at [email protected] I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
2helpful
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Goes out
Please list the model number of your monitor.
Also is the power light flashing? What color(s)?
Unfortunately the symptoms you are describing tell me the inverter/power board inside your monitor needs to be replaced.
1helpful
LG Flatron L1951S-SN 19 in. Flat Panel picture problem
When the picture disappears again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Top Planar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
