Casio Sport #752V Watch Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set hour how to set hour
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on May 31, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291906
Points
7081
If you haven't got instructions on how to do this, you can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
2helpful
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 • Watches
    How do I switch from 24 hour time to 12 hour time?
    Hi greg780,
    Hope it helps.
    Timex 1440 time from 24 hour clock to 12 hour
    Hi bowingman,
    Hope it helps.
    1helpful
    Does anyone have instructions for Nike Imara Fit WR0076?
    How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
    PLEASE READ CAREFULLY
    STEP 1:
    First hold the button for set/light.
    STEP 2:
    wait for the "hold to set" message to appear
    once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
    TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
    STEP 3:
    To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
    *If you are done setting the time press the set/light button, and there you have it.
    If you still need to change the minutes of your digital watch proceed to step four.
    STEP 4:
    After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
    To set MINUTE:
    press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
    *If you are done setting the minute, press the set/light button, and there you have it.
    If you still need to change the date specifically, the day of your watch proceed to step five.
    STEP 5:
    To set date, specifically, DAY:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
    To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
    *If you are done setting the day, press the set/light button, and there you have it.
    If you still need to change the date specifically, the month of your watch proceed to step six.
    STEP 6:
    To set date, specifically MONTH:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
    To set MONTH:
    press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
    *If you are done setting the month, press the set/light button, and there you have it.
    If you still need to change the date specifically, the year of your watch proceed to step seven.
    STEP 7:
    To set date, specifically YEAR:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
    To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
    *If you are done setting the year, press the set/light button, and there you have it.
    If you still need to change the 12/24 hour format of your watch proceed to step eight.
    STEP 8:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
    To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
    *If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
    If you still need to change the power hour of your watch proceed to step nine.
    STEP 9:
    *If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
    To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
    Press set/light to set POWER HOUR.
    How do I set the time for nike imara fit WR0076-002 wrist watch?
    STEP 1:
    STEP 2:
    STEP 3:
    STEP 4:
    To set MINUTE:
    STEP 5:
    STEP 6:
    To set MONTH:
    STEP 7:
    STEP 8:
    STEP 9:
    4helpful
    3answers
    I dont know how to set the time
    STEP 1:
    STEP 2:
    STEP 3:
    STEP 4:
    To set MINUTE:
    STEP 5:
    STEP 6:
    To set MONTH:
    STEP 7:
    STEP 8:
    STEP 9:
    9helpful
    3answers
    Setting the date and time on watch
    time:
    hold left button -- hour will appear and begin flashing.
    press right button to set.
    press left button to advance to minutes, press right to set.
    date:
    press left -- date will appear. now hold left until day flashes.
    press right to set.
    press left to advance to month, right to set. then same again for year.
    2helpful
    2answers
    Timex Watch
    While the time is displaying on watch press & hold the set/indiglo or top left button on watch. The seconds should start to flash.
    Press the mode or bottom left button until the hour digits start to flash.
    Press top right or start/stop button to advance the hour. Then press top left or set/indiglo button to exit set mode.
    Top Casio Watches Experts
    k24674
    Robert
    ZJ Limited
    ZJ Limited
    Are you a Casio Watch Expert? Answer questions, earn points and help others
