I have Vista on a Lenovo Laptop, Conexant High Definition SmartAudio 221
LP Recorder has terminated with "Can't find audio output mixer line for Line (USB Audio) (0047C6F0)" What needs to be done to correct this problem?
SOURCE: I plug in my Inport
Hello. 1. Go to START -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA
PROPERTIES -> AUDIO TAB 2. Make sure that in the Audio tab your soundcard appears as
the Preferred Playback device with USB Audio or
INport as the Preferred Recording Device. There
should also be a check next to the option 'use only preferred device'. 3. When you start LPRecorder you should also make sure that
Recording Device is set to USB Device or INport
and Playback Device is set as your soundcard and
that there is a check next to the option Simultaneous
Playback. Hope this helps.
There may be a conflict with your sound card.
From Xitel:
