Hello. I believe that you should connect with their support service and discuss this topic. I believe that they should help you. If you need to find a new job, I recommend you to check some jobs in salmon arm bc of the following link. I believe that it should help you
The same trouble. Recommendation below helped me
Ps3_info
It sounds like you may have some corrupted data on your hard drive. The link below will help you address this. If you still have trouble then you are having a hardware problem with the system.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
SOURCE: when my career completion gets to 9% on need for
try it again but make it past 9% and see what happens. If it stills says that the memory is cor then what you need to do is find out if your ps3 is a 60G if it is then you its the PS3, the 60G is a Defective ps3, Get the 80G it is great, and if its the 180G or 120 then it might be that two since there new and all. If you dont have either one then i would check out all the other saved memory you have and see if anything elts is core. If it is then its the PS3. Hopefuly i have helped!
