how do i sort this out? the screen display suddenly came up with 'remove cable' + the touch pad wont work at all anymore. tried resetting and tried fully charging it. its basicly a write off yeh?how do i sort this out? the screen display suddenly came up with 'remove cable' + the touch pad wont work at all anymore. tried resetting and tried fully charging it. its basicly a write off yeh?
my samsung mp3 player just froze out of no where its stuck on settings its been frozen since last night i tryed everything i could i tryed turning it off i tryed just everything please help me i just bought it off a friend it was working fine before please help.my samsung mp3 player just froze out of no where its stuck on settings its been frozen since last night i tryed everything i could i tryed turning it off i tryed just everything please help me i just bought it off a friend it was working fine before please help.
I'm having the same problem and the only "fix" I have found so far is to do a reset which I don't like to continually do.I'm having the same problem and the only "fix" I have found so far is to do a reset which I don't like to continually do.
AnonymousJul 16, 2008
Yo le doy al reset y al rato se me apaga, la pantalla sigue congelada.Yo le doy al reset y al rato se me apaga, la pantalla sigue congelada.
When charging, it is fine. When I remove the cable the unit shows remove cable even when the cable is removed. Have to do hard reset with button back based on the only solution posted. That works but need a more optimal solution
I was charging on a usb charger in a socket and I was going to turn off but it has frozen and will not turn off.I was charging on a usb charger in a socket and I was going to turn off but it has frozen and will not turn off.
Mine Is The same Way, Everytime I Take it Off the Charger the "Remove Cable" Shows Up, i Reset It everytime But I Hate DOin that All the Time, and Wen i try 2 Turn It off The "Remove Cable" Sign COmes Up Instead Of it Turning OffMine Is The same Way, Everytime I Take it Off the Charger the "Remove Cable" Shows Up, i Reset It everytime But I Hate DOin that All the Time, and Wen i try 2 Turn It off The "Remove Cable" Sign COmes Up Instead Of it Turning Off
You can't post conmments that contain an email address.
The MP3 player is charged by connecting the supplied USB cable to the
MP3 player and then plugging the other end of the USB cable into the USB
port of a working computer. This cable is also used to copy music files, video and photos to the MP3 player from the computer.
There is a reset button on the mp3 player. Try pressing it using a paperclick or a pin. After reset try to connect it back to your computer. Hope this helps.
First of all, this samsung mp3 player uses its own cable to connect to a computer, you have to use the cable included with your device or yo you can visit samsung .com and checkon ,mp3 player accesories to find the one compatible with your player and buy it. If you already have the cable, plug itinto your computer, you can now delete the songs on your mp3 player using your computer.
My daughter had a similar problem - she was frozen at the power off screen. On closer inspection, at the bottom of the K3 on the back of the unit is a reset button (you will need a pin or paper clip to reset it). Pushed a pin in for a few seconds, reset, all was OK.
The problem is with the battery or the USB cable. Check the cable first if there is any damage replace it,if there is no damage then the problem is with the battery which is not charging get it replaced and ur problem will be solved..
If you have any other problems please feel free to ask..
If you have Windows Media Player, just plug it in using the proprietary usb cable, and it should show up in Media Player. Click the Sync tab, and simply drag and drop.
