Question about Vector Spotlight - 1 Million Candles Power, Model# VEC127Y
I lost my battery charger and how long do batteries last?
Is this worth fixing. Can you find a battery and battery charger and
bulb.
  • 973 Answers
Http://www.dewaltservicenet.com/Support/ServiceCenterLocator.aspx
You can purchase all replacement parts here.
Posted on Jun 05, 2010
SOURCE:
Dewalt DCL040 20V flashlight. The lense on the flashlight got wet and the bulb now won't work. How do I open the flashlight to change the bulb?
https://www.carid.com/images/dewalt/work-lights/pdf/dcl040-manual.pdf
I have had a look at the manual but it only refers to the charger care, as for the "bulb" I doubt that it is (I do not know this item) it is more apt to be an LED (a big one or many small ones) these do not run direct of a battery but work via an electronic circuit which converts a battery voltage to suit the LED. This device can then compensate for a battery that is running down keeping the light bright.
I suspect that this has been damaged by that water as LED's are "hard" to destroy in normal terms lasting for years.
You would be best sending it to Dewalt if that case is intact but let water in you may get it fixed at a reduced cost as it should not happen, if I am wrong on that bulb it would still be worth it for that reason alone.
Hope this helps......
Aug 02, 2017 | Dewalt Camping, Backpacking & Hiking
Rebuilding makita battery instructions
Rechargeable batteries are almost never worth rebuilding and never last very long when they are. In some cases, Makita being one, if the circuit board in the battery detects something wrong with the battery, it 'bricks' the battery. This is not resettable and the battery will not charge on a Makita charger. I'd be looking to get my money back from the repairman since his rebuild didn't take.
Jan 16, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Samsung TL205 Battery Charger http://www.samsung-battery-charger.com/Battery-Charger/Samsung-TL205-Battery-Charger.html Samsung ST50 Digital Camera Battery...
What a battery of information you have accumulated - you must be a bright spark. Please put a plug in it now.
Jun 27, 2017 | Samsung Cameras
I have had my cameraplugged in for a month and whenever i turn it on it says "battery exhausted"
Rechargeable batteries don't last forever. Lithium batteries in particular can fail early if they are allowed to become totally discharged.
It may be worth buying a new battery to see if that fixes the problem.
Have you charged your battery successfully before by "having the camera plugged in"? Most cameras that have removeable batteries do not charge them in the camera, but by placing the battery in a separate charger.
Nov 04, 2010 | Cameras
Blue light on, battery won't charge, unit new 12/14/09
rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
Jun 05, 2010 | Nyko Wii Fit Battery Pak for Nintendo Wii
Bosch PSR 1440 Battery dies in seconds!
hi first make sure the bearings are not seize up if it ok
get new battery
Jun 06, 2017 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
I have a accurian portable dvd player APD-3955 and it works but the charger doesnt charge it anymore. Now the battery died and I was wondering if it just needs a new charger. I got it June 2008.
I had the same problem and I found out that is definitely the battery. I had used mine only a few counted times and after 1 year the battery would not charge. I would plug it and the charge light would turn on and stayed for about 4 minutes and then turned off. I called axion and talk to customer support. The tech said that the internal batteries only last for a year whether you use the DVD or not. They would replace the battery for $60 + shipping costs. As you can see... it is not worth it....sometimes you are lucky and get good stuff for cheap but sometimes... you just get what you pay for.... and this is one of the cases. Yes, I am also very disapponted. What a piece of junk!!!! I can still watch DVD with either the charger plugged in or with the car charger. But it lost its Portable side.....
Dec 30, 2009 | Radio Shack Accurian APD-3955
Craftman model#973.113050 drill/driver. Lost manual.Both batteries are reading yellow and red indicator lights in charger. I find it hard to believe that both batteries 'went' at the exact same time. What...
Batteries do go bad. They sorta die on an age and number of charges basis. I have several sets of DeWalt 18 volt tools. Comes to a total of 8 batteries. I always write the date purchased on the battery. Well, since last December both of my 2006 batteries went bad. I expect the 2007 batteries will go bad this year sometime.
With the NiCad batteries, they are good for a certain number of charges. Which is one reason to run the battery down till it begins to affect performance of the tool. Don't "top off' the charge by putting a battery that is not worn down in a charger, cause you effectively use up one more charge.
I have never had batteries last much more than 2 and a half years.
Now, the Lithium batteries are supposed to have fixed all that --
May 07, 2009 | Craftsman Drills
Battery and camera heat up
Sounds like your cheap-o generic charger has overcharged or fried your battery. Don't put it back in your camera. Buy cheap, get cheaped. :( Go to; www.kodak.com You need a new battery; KLIC-7001 and a universal charger; Li-Lon Universal Battery Charger K7600-C, it's about $35, the Batt is about $30 but it is worth the money to have something that works and a camera that you can now use.
Apr 21, 2009 | Cameras
Vector Spotlight - 1 Million Candles Power, Model# VEC127Y Logo
553 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
freddyfox
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
