Sony Handycam  DCR-DVD108 DVD Camcorder Logo
Tim Foster Posted on Aug 18, 2017
Sony dvd108 camcorder won't record video only sound
Camcorder seems to be working as it plays back the sound but the video screen is scrambled with brown verticle lines and no picture. The screen works as I can navigate through the settings of the camera but it is not picking up any picture. It may have picked up some condensation the other night as it was outside for about 2 hours sitting on a table, could this have done permanent damage?
5 Related Answers
Anonymous
  • 29 Answers
  • Posted on Feb 06, 2008
SOURCE: Sony camcorder
condensation is the situation where a sensor detects presence of moisture inside that is hazardous to the gadget, this will not be removed if no air flow can get inside, best way is to open any side and blow hot air inside. Not hot that can damage some parts.
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Aug 01, 2008
SOURCE: our wedding video
It's possible because your DVD is an RW that someone could have reformatted it on accident erasing the video. If you have something important to preserve make sure you do not use an RW DVD because accidents can happen and it could get wiped out unintentionally.
Anonymous
  • 10594 Answers
  • Posted on Aug 21, 2008
SOURCE: Can not set the camcorder to Super Nightshot Plus mode
To enable " Super Night Shot " option, find slide switch at top of camera as shown in picture...Regards,
Anonymous
  • 10594 Answers
  • Posted on Feb 22, 2009
SOURCE: Sony Handycam Vision videoHi8 will record sound, but no picture.
It is known problem of bad ccd imager in camcorder and requires replacement of that part.
Sony will repair CCD-TRV318 Free of Cost in ccd imager problem.
Please click Sony CCD Imager Support for details.
Good luck.
Anonymous
  • 154 Answers
  • Posted on Mar 28, 2009
SOURCE: Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
I have a sony dcr-dvd108. Can I get some help?
It sounds like your Sony DCR-DVD108 camcorder may have a problem with the battery or the power connection.
For the battery issue, you can try replacing the battery with a new one that is compatible with your camcorder. The Sony NP-FP50 or NP-FP70 are compatible batteries for your DCR-DVD108. You can purchase them online or from a camera store.
As for the "Movie Disabled" message, it may be caused by the type of disc you are using. The Sony DCR-DVD108 camcorder is compatible with DVD-R and DVD-RW discs, but it may not be compatible with all brands of discs. You may need to try using a different brand of disc to see if that resolves the issue.
Additionally, make sure that the camcorder is set to the correct recording mode, such as video mode, and that there is enough space on the disc to record the video. If none of these solutions work, there may be a problem with the camcorder itself, and it may need to be repaired or replaced.
2answers
Recorded a video and when i tried to play it back could not find it again
Sometimes if you have to many videos it will not record it will show its recording but it wont save!
1helpful
Can I record movies onto my pro duo memory stick
In Sony DCR-DVD108, you can save only pictures in memory card.
Video movie can only be recorded on MiniDVD in camcorder.
Thanks.
I am so lost when it come to this thing
You have to convert the movie files from the camera to a format the PC understands. Search Sony's help section for this issue or get a program and adapter to record the video from the camcorder to a DVD on the PC.
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
    • If the problem persists using a different battery, service may be required .
Our wedding video was recorded on a DVD +RW disc on a Sony DCR-DVD108 camcorder. I did watch it on the camcorder once. I then finalized it so I could play in on my computer and DVD player. Now nothing...
1helpful
6answers
Manual
I have lost my digital photo navigator by reinitializing my mac computer and misplaced my digital photo navigator Ver.1.5 where can I go to get a download?
1helpful
Sony Handycam DCR DVD108
The only way to cut off the sound on a handycam is to connect up a blank micro jack plug to the microphone input. Unfortunately the DVD108 doesn't have this option.
2answers
Video screen is scrambled
bad tapes ive seen it before ..buy a different brand brandnew ones and give it another go.
thats why other tapes are working.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
