Health & Beauty Logo
Posted on May 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need instruction manual for Challenger2040 power
Need instruction manual for Challenger2040 power wheelchair .need to see if i'm charging it the right way.Does control switch need to be on to.
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on May 30, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3072731
Points
27242
Sorry there is no manual on-line for the chair. You can get the manual from tuffcare by calling them link below. Also you want to charge the chair with the switch in the off position.
cigna
-dme.html">http://tuffcareonline.com/tuffcare-challenger-2040-reclining-recliner-electric-wheelchair-cigna-dme.html
Where is the breaker switch of my quantum power wheelchair?
However, in most power wheelchairs, including quantum power wheelchairs, the breaker switch is typically located on the main control panel or near the battery pack.
Here are a few steps you can follow to locate the breaker switch in your quantum power wheelchair:
  1. Start by examining the control panel of your wheelchair. Look for any switches, buttons, or indicators that are labeled as "power," "on/off," or "reset."
  2. If you don't find any obvious switches on the control panel, check the area near the battery pack. The battery pack is usually located at the back of the wheelchair, underneath the seat. Look for a switch or lever that can be toggled to turn the power on or off.
  3. In some cases, the breaker switch may be integrated into the power cord or cable connecting the wheelchair to the electrical outlet. Inspect the power cord and check if there is a switch or button along its length.
  4. If you're unable to locate the breaker switch on your own, consult the user manual or contact the manufacturer of your quantum power wheelchair. They should be able to provide you with specific instructions on finding the breaker switch.
Remember to exercise caution when working with any electrical components and refer to the manufacturer's instructions or seek assistance if needed to ensure your safety and the proper functioning of your power wheelchair.
How do you power cycle the Quantum Q6 Power Chair?
Owner's Manual - Quantum Rehab
https://www.quantumrehab.com > owners-manuals
PDF Including Models: Q6 Edge HDTM, Q6 UltraTM, and Q6 Edge ZTM ... product, this icon is represented as a black symbol with a red circle and red slash. ... instructions in this manual and those located on your power chair can lead to personal ...
Basic Troubleshooting Instructions ' Quantum Rehab ...
https://www.quantumrehab.com > resources > quantum-...
... troubleshooting instructions as they pertain to our electric wheelchairs and other power wheelchair accessories. ... INFINFB2594 Q6 Edge Troubleshooting.
Or contact the company direct.
My power wheelchair Quantum 4Front power footrest is not working. Stuck in an upright position. I think a connection is loose somewhere.
If your Quantum 4Front power wheelchair's leg rest function is not working and stuck in an upright position, it is possible that there is a loose connection somewhere. Here are some troubleshooting steps you can try:
1. Check the power supply: Ensure that the power wheelchair is properly connected to a power source and that the battery is fully charged. A low battery can sometimes cause issues with the leg rest function.
2. Inspect the wiring: Carefully examine the wiring and connections for any signs of damage or loose connections. Look for any disconnected or frayed wires that may be causing the issue. If you find any, try reconnecting or repairing them as necessary.
3. Reset the wheelchair: Some power wheelchairs have a reset button or a sequence of buttons that can be pressed to reset the system. Refer to the user manual or contact the manufacturer for specific instructions on how to perform a reset for your Quantum 4Front power wheelchair.
4. Contact customer support: If none of the above steps work, it is best to reach out to Quantum Rehab customer support for further assistance. They will be able to provide specific troubleshooting steps or guide you on how to get the leg rest function repaired or replaced if necessary.
Remember to refer to the user manual or contact Quantum Rehab customer support for specific instructions related to your model of power wheelchair.
My power chair sat for 5 years after having been used for only a couple of years. Now the batteries will not charge at all. Where can I find new batteries for it?
You will need two U1 category batteries for this wheelchair.
The installation instructions can be located in the User manual available at this site.
http://www.invacare.com/doc_files/1125085.pdf
You could pick up the batteries at Walmart depending on where you live.
Walmart EverStart Group Size U1 7 Lawn and Garden Battery
New batteries in Jazzy select traveler have been charging 19 hrs. Charging light is still solid red. What should I do?
Depending on the type of charger, that may indicate that the charger is on, or that there is a fault. Here is a link to some manuals, including the chargers, that may help.
Pride Mobility Products Corp Basic Troubleshooting Instructions
Jazzy 1113 power chair shows charged but control light is blicking. Chair will not move.
It appears that the controls are in Lock Mode. Unlocking Instructions depend on your type of controller. Go to PrideMobility.com to download the proper manuals for chair and controller.
The only time the chair worked [approx. 1/2 hour] was when the repairman cleaned the cables. Since that, the chair charges, turns green for full charge, and only flashes red as soon as the joystick is...
hi.
the link below is for the owners manual for the quickie aspire power wheelchair, free download in pdf format.
http://www.wheelchair-review.co.uk/wheelchair-files/wheelchair-manuals/sunrise-medical-wheelchairs/quickie-aspire-power-wheelchair.pdf
the "cane crutch holder" is an acessory part that you can get, fitted to the back of the seat, to hold a crutch or cane. it does not affect the chair itself at all.
there are two most likely reasons for your problem, neither of which actually involve the arm and controller.
1. if the battery light is flashing 9 times when you try to move, then you need to check the motor locks are engaged properly. see page 27 of the manual for photos and location. these are also known as "freewheel levers" and allow you to disconnect the motors to push the chair manually. if the levers are engaged properly, it is quite possible that the switch, or switch wires have broken and the chair thinks that they are off. these are very cheap and easy to replace and are located where the lever connects inside the chair.
2. if the battery light comes on and stays on, then you may need to have the batteries checked. if the batteries have not been charged for a while then sulphur may have built up on the lead plates inside the battery. this can mean that the batteries will show fully charged, but as soon as you try to draw power, they cannot function due to the sulphur, and instantly show as flat.
any auto shop should be able to perform a battery load test for you to test this. a 100amp load test for about 6 seconds will test the battery performance and let you know if they need replacing. most places will do this test for free but the batteries need to be fully charged first.
hopefully, one of these solutions will work as these are the most common fault for the symptoms you are describing. you should find the manual quite useful as well.
please feel free to ask if you need more information.
hope this helps
I was gifted with a Hoveround MPV 5. It was a
Depending on your use, you need to plug in the batteries to charge at least 8 hours over night.
32helpful
5answers
I need an instruction manual for a Hoveround MPV 4 Power Wheelcha
Call 1-800-771-6565 extention 5000. You will need the serial number of the chair and then they will get you a manual.
9helpful
3answers
How do I charge My Pronto M51 motorized wheelchair?
Margie,   Yes you may charge it overnight. If you use it everyday,charge it every night. Once the charger senses 24 volts it stops sending a charge,so they cannot be overcharged.  I suggest when you go to bed put on the charger and unplug it when you get up in the morning.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
