Does the micro sd card been detected by your computer? If not, you may try other card reader, or other computer. If still does not detected, you may try to go to device manager and see whether the sd card is there, if yes, then you can assign a drive letter to the sd card.
Once SD card shows as a drive letter on PC, you can download sd card recovery software to get back your files. recommended asoftech photo recovery that helped me before. download it from link below
SD Card Recovery SoftwareYou can refer to this card recovery tutorial
Recover files from SD CardIf above does not work, you may have to format the memory card (use quick format), and then use Asoftech Data Recovery to scan again the memory card and recover your files.
