Whirlpool RBS275PD Electric Single Oven Logo
Posted on May 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code EO -F2- Any one know what this means
Error Code on the digital screen has oven locked up
Megan W
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Whirlpool Expert 84 Answers
  • Posted on Aug 23, 2017
Megan W
Whirlpool Expert
Level 2:
Dedicated:
Answers
84
Questions
0
Helped
76483
Points
479
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 [email protected]
Error code EO -F2-  Any one know what this means - rsz_fullsizerender_14-h3opwjov4mbbgf4waxk4mkod-3-0.jpg
Anonymous
Level 2:
  • Expert 327 Answers
  • Posted on May 30, 2010
Anonymous
Expert
Level 2:
Answers
327
Questions
Helped
176194
Points
985
Hello,means shorted keypad and need to replace the electronic range control/clock
Thanks
1helpful
What is the eo f2 error code mean on a whirlpool oven
E0 F2 is a stuck key on the keypad. If your keypad is not available from the factory you may find a replacement unit here: http://www.fixyourboard.com/ledgestone.html
2answers
EO F2 The oven will not start or stop. I can not get the oven to work but it will beep with this EO F2 message sometimes.
Hello Sonya,
The E0-F2 error code means that the oven temperature was higher than it's supposed to be. Usually the oven overheats because of a defective oven temperature sensor and the sensor should be checked. 11_3_2011_2_07_54_pm.jpgthis is what the sensor looks like...it is located within the oven chamber(usually in the left side) to check it,it needs to unplugged and using a mulitmeter set to measure ohms,check the sensor to be between 1060-1100 ohms at room temp. if the sensor is way lower/higher that 1060-1100 at room temp the sensor is bad and needs to be replaced, if the sensor is within that range then the control board is the problem.
GENE
1helpful
Receiving an E0 error code when trying to clean a Whirlpool Accubake oven
The EO error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The EO code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Sep 18, 2011 • Ovens
2helpful
New Wall Oven with error code F2 EO "Keypad Disconnected" How to fi?
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
2answers
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 • Ovens
3helpful
Shows EO-F2-CODE
F2 means something is wrong with the keypad. Check that the keypad is firmly connected with the control board and press Cancel. If you get the code after a minute, replace the keypad.
1helpful
Blinking EO and F2
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
2helpful
3answers
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
