Dear
Deve Home Sensor Error indicates a problem in the fusser unit.
Unplug the power cord ,check the fusser unit and plug it back in.
If the problem persists, Replace to the
Main board.
That error means there is a problem in the fuser, could be lamp out, thermistor bad, overtemp sensor tripped, any number of things. You can find a new fuser at www.precisionroller.com
There is a problem in the fuser unit check component oven lamp thermistor and fuse thermostat etc. ..and then if not dispear the message you change main board
hi if u check the samsung manual herehttp://www.wisconsinimaging.com/downloads/clx3160manual.pdfthen u will find it in page 79 and it saysThere is a problemin the fuser unit.suggestion:Unplug the powercord and plug it backin. If the problempersists, please callfor service.
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
Error message is listed as Deve Home Position Sensor Error, relates to signal not being received within the necessary time limit from to the sensor after rotation of Rotary Developer. A specialised problem requiring attention from a trained service person. Not something you could expect to fix yourself. See p198 of the Service Manual.
