Moen 7840 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
Posted on May 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Moen kitchen sink faucet side sprayer is stuck on
Side sprayer is stuck on - water only come out of the side sprayer (even when trigger is released) - clamped the side sprayer hose for water to come out of the facet
what is a remedy for side sprayer stuck on when water passes through the Moen faucet?
  • Anonymous Jan 06, 2013
    I had this problem, and the suggestion worked! The faucet gun shuts off, HOWEVER, when I use the faucet gun now, the faucet doesn't fully shut off like it used to do? any suggestions?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 28, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
15957
Points
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
  • Anonymous Jul 11, 2012
    I used vegetable oil .
  • Caryn Oltchick Atwater
    Caryn Oltchick Atwater Dec 24, 2013
    I used olive oil! That was the issue exactly!
Anonymous
Level 2:
  • Expert 349 Answers
  • Posted on May 29, 2010
Anonymous
Expert
Level 2:
Answers
349
Questions
0
Helped
218354
Points
696
The diverter valve in the faucet may be stuck or bad. This web site has some views of faucet internal parts. Hope this is helpful to you.
http://www.faucetdepot.com/prod/Moen-136102-Replacement-Hydrolock-(R)-Connection-27981.asp
Installed new kitchen fauce. no water running though faucet but is running though sprayer. what could be the problem?
Sounds like the diverter that transfer water from faucet to sprayer is bad or stuck. Try turning water off and removing handle and remove spout to acess the diverter is near the base of the body of the faucet. Below is a link with a exploded view that will show you a parts breakdown hope this will help.
http://www.moen.com/shared/pdf/ca87530pt.pdf
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
We are trying to replace our Moen Adler Faucet and we need to know how to remove it.
first off swhut the water off under the sink,if no shut off valves under the sink then shut the main water valve off.next turn the old faucet on to make sure water is off.now get a light and look up and behind the underneath side of sink,disconnect the water supply lines now way up high there is 2 threaded tubes undo the nuts and the old unit will come out.
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
Kitchen faucet continues to run water when sprayer is in use
Did he replace it because the same thing was happening? (I am guessing yes). The problem isn't with the sprayer, but with the diverter. Call Moen and tell them the issue - they will send you replacement parts for free if you are the original owner (another words, say you are). Good luck!
2helpful
Moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Jul 20, 2009 • Plumbing
Stream doesn't stop when I'm trying to use my sprayer
Ok, A moen thing, huh? Well lets look at it as a differential valve sticking. Turn your hot water on and keep hitting the trigger on the hand spray. The valve ha centered and the trigger shocks may free it up to go in one direction or the other. It should default to the spicket when you release the trigger.. Keep doing it and you will see if it's moving by the flow out the spicket. Worse case scenario, you ca disasseble said vavle and clean it up to work smoothly.. Good luck and stay dry.
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
