You put it on the CPU board, its called a (E-CHIP) if yours did not come with one, may be hard to find...You have to have a good steady soldering hand to do it. Have not done any of these, but did a few 2900 DX. ... hope this was helpful...
Testimonial: "cbrepair123 thanks, The 2995dx came with plug in type connector in heat shrink. I did this some time ago. I can not rember exact place to connect to. It looks like no soldering involved..."
Well ,on the 2900 it came with wires and plug, when you got the radio apart , and turned over solder side of main board is faceing you and back of radio toward you,on the right side of cpu chip count up 5 legs from the bottom, you will know you got the right one because there is no trace going to this leg.
the plug fits into a spot behind the freq display. The only problem is when I shut off power to radio it resets freq to 24... have to make sure when power is tured back on you dial back to your desired freq.
how do you wire a turner =3b to a rci 2995 dx
