The like a switch inside the psp that when the umd closes it turns on the umd and u see it moving and the read light but then it stop after a few seconds but this all happen when my little bro dropped it please give me addvice
The problem is that when your brother dropped it ,, he must have broken something in the reader , where now the reader cant be able to read the UMD disks an easy solution is to make there is no dust in the UMD reading place or trapped in the UMD, second of all if the reader is really broken you can go to the nearest psp fix shop he will tell you the problem and whether you wanna fix it or not... finally, the most preferred way is by giving up on UMD and start using psp isos downloaded from the internet for free,, all you need is a memory stick preferred 2gb or higher... and a CFW which u can find tutorials all over youtube finally you just play the games off of your psp memory stick for free... hope it helps ^^
It would look like this if your UMD door was off.
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
After this try and see if it is reading UMD again.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
