I cant format 2 gb sandisk memory card in my pc, when i insert in the mobile it says memory card not inserted,when i open it in my pc it says,memory card not formatted,want to format but when i do so it comes windows was unable to format it.
reformat your card through your pc. don't go for quick format. if it doesn't works after that also then get a software 4 low level formatting. if then also it doesn't works ask me again.
kindly rate my solution.
Try to format your memory card on a pc. after formatting, try putting some songs or any other data on the card from PC and then insert it on to ur mobile phone.
If is still does not work on mobile then you need to contact Nokia as the card is working fine.
it will need to be smaller then 8gb...... also micro SD......... NOT micro SDHD .....you also need to format it using the phone (check user guide for info on how to do this)
hope this works for you .....good luck
Put the card in your phone, link the phone to your pc and format the card through your pc. You should see two additional drives, one for your phones memory and one for your card. I had the same problem with my phone but it is now sorted !
