DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
Posted on May 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dish error 077
How do I unlock the front panels of the dish dvr
Mike.H-DISH_Network
Level 2:
  • DISH Network Expert 246 Answers
  • Posted on Jan 19, 2011
Mike.H-DISH_Network
DISH Network Expert
Level 2:
Answers
246
Questions
0
Helped
90899
Points
341
Hi cesarchivas2 what you will need is your password to unlock your receiver, if you do not remember it you will need to call in and reset your password. Then you will have your receiver unlocked, the reset when you call in can take up to an hour to fully take effect.
Mike Houston of DISH Network
tip
DISH Solo DVR VIP612 Manual Download
Download DISH Solo DVR VIP612 Manual
Would you like to review the features of the DISH Solo DVR VIP612 ?
Have you lost your DISH Solo DVR VIP 612 Owners Manual?
Would you like a digital, searchable, pdf version of the DISH Solo DVR VIP612 Users Guide?
Follow this link (& click FREE) to download a pdf version of the DISH Solo VIP DVR 612 documentation.
I hope that helps.
____________________________________________________________________
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 • Televison & Video
tip
DISH Solo VIP612 DVR Manual Download
I hope that helps.
on Jul 04, 2010 • Televison & Video
Xerox 4110 fault code 077-330
ERROR CODE: 077-330, Front Door/Panel - DAMAGED
My Dish DVR 625 does the "program guide download"
Hello! Dan Busa with Dish Networks customer service department. This sounds like it may be a signal issue, I would make sure the cabling is tight and in good condition. You also want to enable your inactivity standby having it disabled will only make this worse. If everything seems ok you may need a technician.
tip
I hope that helps.
on Jul 04, 2010 • DISH Network ViP 612
Need to get the PIP turned off.
wrs1350,
This message indicates that a password was setup to lock the front panel buttons on the receiver. To unlock, the password should be entered. If you can't remember your password, you can call 1-800-333-3474 to have the password reset. It usually takes 1 to 2 hours to reset. I hope this helps.
Ray Calo
DISH Network
My dish DVR HD control doesn't work
lumaes200,
You have indicated that you have a 622 DVR receiver, since this is where your posting was found. When you trying any of the DVR functions on the remote, do you get an error message (024 or 311) indicating that the function is not available at this time? If not, try unplugging the receiver for 10 seconds from the electrical outlet. This will reboot the receiver and re-acquire the satellite signal. Once the picture returns, try the DVR function. If the problem continues, please call 1-800-333-3474; we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
Dish 510 DVR that wont record properly or play paused TV show
Make sure that the software is correct. Should be P4.07
you can go into the DVR and replace the hard drive but I would suggest getting Dish Home Plan, Replace the receiver and then cancel the Home Plan. Talk to Dish Network and they will work with you.
for tech support go to: tech.dishnetwork.com
2answers
Dish 625 DVR recorder won't play recorded shows. It gives me an error code (05)
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
