Canon PIXMA MP830 All-In-One InkJet Printer Logo
Anonymous Posted on May 28, 2010
Error 5C00 results when trying to print
My printer makes a horrendous ratcheting noise when I turn it on, and when I try to print. Can't see a paper jam. When I try to print the display screen states that an error 5C00 has occurred and try restarting; if this doesn't work (it doesn't) check the manual (I did, no apparent solution therein).
Thanks if you can help....getting tired of replacing printers that cost as much to repair as to replace after ridiculously short service periods (less than two years with light to moderate duty).
Chee Seng
Level 2:
  • Expert 284 Answers
  • Posted on May 29, 2010
Chee Seng
Expert
Level 2:
Answers
284
Questions
0
Helped
163943
Points
706
[5C00} & Light Blinking 4 times = Purge Cam Sensor Error. That's mean there is an error occurred in the purge unit. You may either need to replace PURGE UNIT or LOGIC BOARD to solve out this error. Thank you.
Testimonial: "Your insight is MOST appreciated; however I just did the math, realize that a new one will cost me $5 and change per month for the next 18 months, so I will go with that. Dis-assembly, parts installation, cleaning up the mess and re-assembly is not something I have the time or inclination to get into. But thanks again very much. "
  • Chee Seng May 29, 2010
    [5C00} or Light Blinking 4 times = An error occurred in the purge unit. You may need to replace purge unit or logic board.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1031
Points
See nothing is blocking the cartridge movement, if not get it serviced
  • Anonymous Oct 30, 2012
    see nothing is blocking the cartridge movement, if not get it serviced
1helpful
Canon pixma MarkII pro 9000 has an error 5C00 or purge error?
That is probably some paper or a foreign object inside the machine. Check around the waste station and at the far end of the printhead travel in both directions. Remove any found foreign objects and restart the printer. If there is nothing there to find - it is probable that the is a mis-alignment of the gear train that selects the various functions of cleaning, paper feed, and waste purging. In that case, there is not a lot you can do short of a complete strip down and rebuild with no guarantee of succes.
3helpful
I have a Canon MP630. It is making a horrendous noise, like cogs scraping, very loud. Error message Service Error 5C00. Any ideas?
I have the same problem & it's driving me nuts! Can anyone help with this or is it a throw away job?
1helpful
Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Error 5C00 loud scratching sound when i switch on the printer. what do i do?
5C00 is a purge assembly error, look inside on the right with a flashlight, make sure there is no paper scrap or or anything that doesn't belong. If nothing is there you need a new print engine, QM2-2020-000 around $100.00
Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
1helpful
2answers
Canon pixma ip90 printer
if your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Error Message 5C00
4 times is usually Automatic print head alignment
Set a sheet of plain paper (A4 or letter) in the ASF.and adjust.
old marine
old marine
ZJ Limited
ZJ Limited
