Gas line with filter broke inside tank how to replace poulan pro 31cc trmmer
Get new line cut end at an angle , lube with oil and twist it in, snag the line and pull it out the filler hole and insert filter on the end, connect and enjoy.
my homelite has 2 lines to the tank. make sure you have the right hose with filter goes on the side to the carburator and the primer ( mine anyway ) is a different size line. i suggest you change both lines and go with inside diameter measurements that is measured with drill bits . that is the easy way. dont mix up lines to where they go.
