SOURCE: Karcher pistol gun has broken
Make sure you DO NOT have a check valve (this is what stops your hose running when you disconnect from the hozelock fitting) in your hose pipe system, This will send a shockwave through the pressure washer and destroy the fitting you mentioned. They can be easily removed.
SOURCE: My karcher k490 has a
The wand as it is called is replaceable. You can contact a local dealer like www.arcolawn.com who gets these parts through Stens.inc. You can install the wand yourself.
