U4 System transmission between indoor and outdoor units Daikin
Failure of transmission between indoor and outdoor unit. Need details of possible causes and ways to fix
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps
I take the time to answer your question so please rate me
Have you found the problem with ya A/C yet PD with the U4 code, if so what was it.
Daikin air condition outdoor unit pcb.how to repair
Toshiba inverter ras10nk timer light and options lights are blinking continue
