Kenmore 4.8 cu. ft. / 136 liter Chest Freezer 13401 Logo
Posted on May 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The bottom drawer on my Kenmore 4.8 chest freezer will not open. I defrosted the top compartment but the drawer won't budge.
Terence Fourie
Level 3:
  • Master 909 Answers
  • Posted on May 28, 2010
Terence Fourie
Master
Level 3:
Answers
909
Questions
0
Helped
375323
Points
2542
Normally it is an ice build up on the inside. Suggest overnight defrost to sort this problem out.
Chest freezer ice is filling up around the top of the inner lid
Turn it off, remove the stock, tap the sides with a block of wood and scrape to the bottom of the freezer with a dustpan and scoop it out. Refit the stock and switch back on. Takes 10 minutes. Check the lid seals properly once defrosted and check it's not accidentally in superfreeze mode.
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 • Freezers
2helpful
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
Kenmoew 4.8 cu ft 13.6 lt chest freezer
need more info model what type of frezeer
Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
1helpful
Kenmore chest freezer about three or four years old.not cooling
Probably a freon lean and not worth repairing. You can never find the leak in a chest freezer. Recharging will buy a little time but you can never reallly trust it again.
My bottom drawer won't open?
Can you supply more info? Was there food in there that could have frozen in a position to lock up the door slides?
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
