If the icons indicate there is a Wireless Network Connection available but you cannot see any web pages, do the following to verify the correct, current DNS IP address is selected.
1. Right-click the network icon, and select Network and Sharing Center , select Manage network connection .
2. Right-click either the Local Area Connection or the Wireless Network Connection and select Properties .
3. On the Network Connection Properties page, highlight the Internet Protocol option, and select Properties .
4. Select the Obtain an IPv6 address automatically and Obtain DMS server address automatically options, and then click OK .
5. Returning to the Network Connection Properties page, on the Networking tab, select Configure .
If there is a Power Management tab for this device, de-select the Allow the computer to turn off this device to save power option.
6. Restart the computer.
The computer retains a list of all the networks to which it has been connected, and it tries to connect to the first wireless network it discovers in the physical area. You must determine if that is the network you want and if the connection is using the current IP address and password.
1. Right-click the network icon and select the Network and Sharing Center option. The graphic display indicates if there is or is not a connection.
oIf a list of available wireless networks is displayed, highlight any active connection and then select the option to Disconnect the computer from all the networks.
2. Now that all wireless networks are disconnected, manually set up a new wireless connection.
Do not click Connect to refresh a connection. If there was a problem with that connection, just clicking Connect will refresh the same wrong information.
3. On the Network and Sharing Center window, select Connect to a network , then select Set up a connection to a network , and then Manually connect to a wireless network and click Next .
4. When prompted, enter the required network information, and then click Next .
o Network Name (SSID)
o Security type
o Encryption type
o Security key or passphrase .
Wi-Fi technology enables wireless Internet and network access through public and private hot spots.
These hot spots are widely located in homes, restaurants, bookstores, coffee shops and other businesses, so you can keep connected wherever you may travel.
To connect to Wi-Fi, you must have an enabled wireless adapter on your computer.
Most modern laptops and many desktops have this adapter built into the system, but many lack such capabilities.
However, a wireless adapter is easily installed via USB, which allows you to connect to available networks through Windows 7.
Enable your wireless adapter. Most laptops have a hot key labeled with a radio antenna.
Hold the "Fn" key and press this key to toggle wireless on or off.
Desktops likely have a physical antenna on the back of your computer that is typically always on. If you don't see such a hot key or antenna, you need to acquire a USB wireless adapter.
Attach the USB wireless adapter to an available USB port on your computer.
Windows 7 will automatically install the necessary drivers for most adapters.
If it does not, insert the CD that came with the USB wireless adapter into your drive and choose to install their drivers.
Restart your computer if you do not see a wireless icon in your Windows 7 notification area.
Click the wireless icon in the Windows 7 notification area and click the network name to which you want to connect.
If this is your home network, the correct network will likely be the one with the strongest signal.
Click "Connect" and enter the wireless security passphrase, if required.
Only secured networks will ask for a passphrase, but some public networks will require browser authentication instead.
Open your browser and navigate to any website.
If the hot spot requires browser authentication, your website request is redirected to an information page.
Follow the instructions on this page to get Wi-Fi.
This may entail clicking "Accept," entering a given password or entering a cell phone number.
After authentication, attempt your website again to verify accessibility.
Hope this helps
