Hello there:
There's no heat
If your dryer doesn't heat, check these:
Power from the house
Check to see whether there's power getting to the
dryer. Is it plugged in? Check for blown fuses or tripped circuit
breakers--your dryer uses two fuses or circuit breakers. The dryer could
tumble but not heat if only one of the two fuses is blown. If you have
circuit breakers, one of the two circuit breakers can trip, even if the
two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but
doesn't trip the circuit breaker or blow a fuse. The heating element is
simply a long coil of special wire. You can check it for continuity with
an ohm meter. No continuity means the element is bad and you need to
replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to
the exhaust duct inside the back cover panel. The fuse--which is about
an inch long--is usually embedded in black resin and mounted in a white
plastic housing. If the fuse has blown, you need to replace it. (You
can't re-set it.)
Wiring
A common problem is for the main wiring connection
from the house, at the dryer, to burn and break its connection. Because
the dryer can still tumble with partial power, the connection may be
only partially defective. You may need to replace both the power cord to
the dryer and the terminal block inside the dryer that the wire is
attached to.
I will post the pictures of the heating element in a seperate post
Best regards mike
Location of thermal fuse and the heating element, on the amana le3402w
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
