HP Compaq dc7600 Convertible Minitower PC Desktop Logo
Posted on May 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audio Panel HP DC 7700 Minitower case with Hp 7600 motherboard
My HP DC7700 mother is broken, so i replace motherboard. However, the motherboard is HP DC 7600. Every thing is ok except Front Audio Panel. I still get an error message that I did not connect to Front Audio cable. Indeed, it is connected. I realized that the connection of audio cable is not the same combination. how can i solve the problem.. Thanks advance
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Oct 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2702
Points
Just change the placement of pin 7 to pin 4, but its only to solved the error massage, the front panel audio will not work properly Audio Panel HP DC 7700 Minitower case with Hp 7600 - e6f61c3.jpg
Catalin Turcu
Level 3:
  • HP Master 4,924 Answers
  • Posted on May 27, 2010
Catalin Turcu
HP Master
Level 3:
Answers
4924
Questions
0
Helped
1232007
Points
13383
Go to the manufacturer site and download the manual ...not just the schematic...in the manual you have the picture with the pin numbering ..and the functions .(places on the plug ..) and the wires are labeled
2helpful
Audio wiring problem on HP Compaq DC7100 CMT with DC7700 motherboard
You have a problem with HP connectivity. When I moved my dx7100 motherbard into another casing I experienced that error and also chassis fan not detected error. Chassis fan error is easy to remove, You only need a fan with at least 3 cables (with sensor) and plug it into 4 pin chassis fan connector. Audio conector have 10 pins (eight pin missing for orientation (with followed numerication
2 4 6 10
1 3 5 7 9
If you only want to get rid of the error ( with no use of back audio(use of another soundcard)) then short pins 2 and 7. But if you want to use back connectors, then you must bridge with jumpers 1-3 for microfone, 5-6 for audio L and 9-10 for audio R.
I've bee searched thru internet and didn't find this trick anywere.
HP 7700 how do I install an ethernet control driver
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver
if you computer came with a motherboard disk the drivers could be on it or the one supplied by your ISP internet service provider
hope this helps
1helpful
2answers
How can i install my hp compaq dc 7700 945 audio driver
HI,
Installing the HP DC 7700 Drivers is a little tricky. You may have installed the drivers and its not working I guess. This is because the HP DC-7700 has HD Sound and it required "Microsoft Universal Audio Architecture Bus, which can be downloaded/ installed from the following link. Choose the Operating system you have on your PC and get the drivers.
HP DC7700 Drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
1helpful
I formatted my hp dc7700 and now i cancot run my internet from lan and at the same time cant play any sound
What I could understand from your question is that your Driver softwares are not installed in your system.
Go to this site and click on 'Download drivers and software'
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3232101&lang=en&cc=us&prodTypeId=12454&prodSeriesId=3232028&taskId=135
You will now get an option 'Select Operating System'. Click on the OS that you have installed in dc7700
Now download the following drivers Driver - Audio Driver - Chipset Driver - Graphics Driver - Modem Driver - Network
and install the same on your dc 7700. Now you will be able to play sound and also browse internet after you configure the LAN (TCP/IP) properties.
14helpful
2answers
I want to download audio driver for hp compaq dc 7600 on windows xp. What is the best driver for it? Thanks for help Maz
Audio drivers for this computer are here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=472278&lang=en&cc=us&prodTypeId=12454&prodSeriesId=472276&taskId=135
Original drivers from HP
5helpful
I cannot install pci device driver in hp dc 7600
pci device driver in hp dc 7600.
go to Google.ca search for uPCI-200L. Download the driver for that device..and solve the problem. Your PC has 2 PCI serial port (comA and comB). Good luck.
4helpful
Sound Drivers for HP MotherBoard
Here's the download site for yor machine. Choose your operating system and the whole set of drivers will come up.
Good luck.
Ron
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
