My paper keeps crumpling up as I'm printing it out, but it's in line with the tray so I'm not sure what's happening. And also, just recently, as I print out a sheet, the ink blotches and does not distribute evenly along the text. One line will be dark and the next will be faded and not fully formed. How do I correct this? The ink levels are full, and I do the maintenance.. I'm not sure what happened- it used to work perfectly.
SOURCE: paper jam laserjet 4
The rollers and guide on the back need to be cleaned and lubed. On the rubber rollers use a mild cleaning solution, on the bearings use a light oil and on the black plastic rollers you will see post that sticks out from the center of the roller here you will want to use a light grease (lithium).
Hope that helps...
SOURCE: paper feed problem-wont go through- crumpling up as it tries to go through
You probably have a piece of paper stuck at the place where it's crumpling. Take a good look and carefully extract it. It may be small, so look hard.
SOURCE: My printer won't print black ink even though the cartridge is full
try to clean the nossles with software from the manafactures website
SOURCE: Shows black ink full but not printing
Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost. Have a happy experience.
SOURCE: samsung 1340 crumpling copies as they print
how old is your printer if it is too old maybe you need to change the fusing unit
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
