Microwave Ovens Logo
Anonymous Posted on May 26, 2010
The paint in the cavity of my 6 year old microwave oven is peeling from the top. I don't know why. Is it safe to sand off the loose paint and touch it up?
Anonymous
Level 2:
  • Expert 276 Answers
  • Posted on May 27, 2010
Anonymous
Expert
Level 2:
Answers
276
Questions
0
Helped
205513
Points
890
Sand off the loose paint and make sure that there are no holes in the cavity. If there's holes the unit is not safe to use.
If it's just surface flaking, it should be safe to sand back with fine grade wet/dry sandpaper. We usually respray with automotive paint in a colour close to the cavity colour.
Testimonial: "thanks!"
2answers
Panasonic Inverter microwave, paint starting to flake under the ring.What can be done?
dont ever in future buy a microwave with a painted interior as it will always peel.......better to buy a stainless steel one.i don't know if there is a special paint you can buy but if you look on the internet you will find one.
The bottom inside part of my Oster microwave is peeling up pretty bad where the plaste circle with wheels turn the glass. Don't use it much for this to happen....is it still safe and is there any recalls...
Using the microwave with exposed metal can cause additional problems. You can remove the loose paint, lightly sand the area and reprint with microwave cavity paint. The paint can be purchased from your local parts distributer, or find it online. Follow the instructions on the can.
11helpful
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Paint peeling
The paint you need is called microwave cavity paint. If they don't have it at your local hardware store, you may get it at www.appliance411.com/data.php?rc=277
Be sure to sand the area first with some emory cloth to remove any loose paint flakes.
3helpful
Paint worn off inside and metal showing
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
My sharp microwave oven sparks and pops when in use.
1. You have to clean m/w inside from all kind of grease and food resedue.
2. Inspected m/w cavity inside and clean all burning spots with sand paper.
3.Apply touch paint on this spots.
Different color touch paint you can buy at any appliance patrs store.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
4helpful
Inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing, which can be messy.
3helpful
PEELING COATING IN MY SUNBEAM MICROWAVE OVEN
Yes, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing.
13helpful
3answers
Peeling paint
You need to thoroughly clean it, then sand it smooth to removew all the loose paint.
Once it's squeaky clean and dry, you can apply high-temperature appliance paint, which is available in brush-on or spray-on form at big box stores like Wal-Mart, home improvement centers like Lowe's and appliance parts stores.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
