Samsung HLP4663W 46" Rear Projection HDTV Logo
Posted on May 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung hdtv scrfeen half black half res
Split down the middle half screen red, other half black..even with nothing hooked up and just power turned on...settings make no difference and have tried rest to defaults.,,
  • Herwig Devrieze
    Herwig Devrieze Jan 23, 2019
    Hello
    Seems the T-con board defective. It is a common problem with Samsung TV
    Parts cost on Aliexpress = 20 bucks
    Take a look on U tube, how to replace T_con board
    Succes
dick davis
Level 3:
  • Samsung Master 610 Answers
  • Posted on May 26, 2010
dick davis
Samsung Master
Level 3:
Answers
610
Questions
5
Helped
222153
Points
1808
Sounds like the color wheel is not turning properly. I would recommend calling 1-800-samsung to set up repair with an authorized service center. I would not try to replace it yourself. The part costs $120.00- $180.00.
2helpful
LN46A530 Samsung LCD -half a screen black-stays for 30 minutes, than turn to some what normal, but not quite all.What is the problem , what is the part to replace?
is it completely dark or just very dim or dark on one side? if it's just dark on one side, you have a failing LCD panel, very common for older Samsung panels. If it is completely black on one side split down the middle, you could be dealing with a bad panel, bad t-con board, or a faulty LCD panel ribbon connection.
2helpful
Won't turn on screen until it warms up
i had this problem with my samsung a while back same symtoms everything and after hectic research i replaced a few blown(swollen) capasitors on the power supply and bam! it worked? its worth a try hope it helps
I have a 40" Samsung
Call Samsung (1-800-726-7864)about the problem. They are aware of theproblem and offer a 1 time free repair. Therepair is generally done in your home. Samsungdid tell me that they even take care of the bill outside your warranty. I hopethis helps
1helpful
Permanent split screen down middle by black line
The GPU has overheated that is what causing this problem.
You will need to stop the heat build up and get it repaired - you can even do this with a good guide or send it in.
Stupid TV
Ur power supply have burn capacitors,useally in the middle of the power supply board is the burn capacitors.Look for bulk up caps or split out.
8helpful
3answers
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
52" Samsung that the top half of screen goes black.
the HDTV has a heat-related problem check your fans. Do they remove heat? the vertical chips paint the screen from top to middle and, middle to bottom so; your top to middle vertical chip is overheating as is your video chip; that is why you have "glitter" in the back ground. get rid of the heat or, bye,bye TV.
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
LG 42PC3D plasma television -- screen split down the middle
Our 42" LG picture is also split down the middle. It doesn't matter if it is cable or a DVD. I would love to know if anyone has found out the solution to this prob. The TV is only 3 years old...
3answers
4 inch thick black vertical line down the middle of the screen
A month from purchase you shouldn't even bother yourself with this. Their problem.... give the shop/samsung a call. If you have no reason to suspect any cable problem, and a different input device(other than the DVD) doesn't affect it, don't waste time and get on the phone. Good luck
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
