Hello, I have an older Toro Lawn Mower that I got from a friend, the model number tag is missing. It looks similar to the one in the picture, but it is red. I went to use it the other day and it wouldn't start. I saw the fuel line was really bad, one thing led to another and I ended up removing the carb and manifold assembly. I replaced the fuel line, put new gaskets, cleaned out the carb and reinstalled everything. It seems like it is not getting fuel. When I prime it the rubber primer button seems really week, I keep pumping it and it never feels like it pressurizes. If I spray starter fluid down the intake it starts then immediately dies. Any suggestions? Thanks, Rob
SOURCE: engine will not stay running
Hi
When the engine stops check the spark at the spark plug.Check compression(remove the spark plug and ground the plug wire on the engine,seal the plug hole with your thumb.Operate the starter.If the compression preasure blows your thumb off the hole,the compression is adequate for the engine to run.Now priming the engine(put some gas into the spark plug hole,back the spark plug and try to start the engine.Let me know. savumihai71 regards
SOURCE: I have a 6.5 hp toro lawn mower. starts, but
the diaphram in the carburator is bad or broke which is behind the primer they brake or rip the will not keep gas flowwing through try that
SOURCE: My lawn mower starts, runs for about 5 seconds and
The engine is starving for fuel, that is why it will keep running while you force the fuel to the engine with the primer button. At this point, the carb will have to be removed,disassembled and cleaned. I'm sure you will find blockage and dirt in the carb and also in the small orifices for air and fuel flow.
SOURCE: toro model number 200065 won't start. New gas,
some toro primer bulbs don't fill up with fuel but blow air into a chamber in the carb that has fuel in it so when you press the bulb, the air sprays fuel into the carb ( just a little) So since it won't start, the bulb probably has a very small crack in it. replace it and then try it.
SOURCE: toro recycler 20017 is very
The carburetor may need to be serviced. You need to find a parts shop that handles Tecumseh parts. You will most likely need a rebuild kit for the carburetor. The carburetor part number is 640303. The rebuild kit is 632809. The Tecumseh engine company shut its' doors 3 years ago. Finding parts is becoming harder and harder. I've heard that someone has bought Tecumseh over the winter but it is unknown when the new parts will hit the market. Best of luck to you.
what make of engine is on the unit?
