Bulova Watch Logo
Posted on Mar 04, 2018
I bought an alain silberstein copy,and it doesn't have a manual. i figured out how to set the time,month,and date. i want to know how to set the day. if you have any other detais on the watch, i would appreciate it. it's the "classic skeleton"model, with three knobs. thank you,george
4 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 14, 2009
SOURCE: setting time, date, month and day for diesel model dz7087
As there is no possibilities to download manual for your watch, you have to contact Diesel yourself by email or by phone. Here is the contact info:
If you need help with product information, ordering assistance, or returns information you can contact us via one of these three options:
Diesel Time Frames Customer Service
2280 N. Greenville Ave.
Richardson, TX 75082
TEL: 800-699-2556
[email protected]
Don't forget to rate, please.
Anonymous
  • 2071 Answers
  • Posted on Jun 27, 2009
SOURCE: Where can I download instruction manual?
Just click this link and ask there for a user manual:
http://www.a-silberstein.fr/us/accueil.htm
Here you can download also:
http://safemanuals.com/brand-user-guide-instructions-owner-manual/ALAIN%20SILBERSTEIN
Good luck:
Regards:
VOTIT
Anonymous
  • 206 Answers
  • Posted on Jul 30, 2009
SOURCE: Day, date and time for a Bulova TFX watch
Step 1. When the second hand re a ches 12 o ’ clock (the zero or 60th second mark ) , pull the crown all the way to the “OUT ”position (you will hear two “ cl i ck s ” ) .All hands will stop.
Step 2. Turn the crown to move hands FORWARD (clockwise) until you see the date (for date only) or both day and date change.This establishes midnight, t h e b e ginning of the day.
Step 3. For A.M .time, continue to move hands forward until the minute hand is approxim a t e ly 5 minutes beyond the desired minute marker ;then ,gently turn b a ck to the same marke r. For P. M .time , follow the same procedure ,but first a dvance  the hands past 12 o’clock .
N O T E : The date will advance automatically at midnight, p rovided that A . M .a n d P. M .h ave been established (Steps 2 and 3).The watch calendar is pro grammed for a 31-day cycle.The  refore ,on the fi rst day of any month fo l l owing a month with fewer than 31 day s , the date must be advanced manually (see Step 5).
Step 4. When the time standard by which you are setting your wa t ch ( e.g.,telephone beep) re a ches the 60th second, push the crown all the way to the “ I N ”position . All hands will start instantly.
Step 5. Pull the crown to the “ I N T E R M E D I AT E ”position (one “ cl i ck ” ) . Your watch will continue to tell time. S l ow ly turn crown one way until the correct date a p p e a rs .Then for day/date models, s l ow ly turn crown the other way until the correct day appears .
N O T E : The day is printed in two successive positions on the day indicator: i n English and in Spanish on U. S .m o d e l s ; in English and in Fre n ch on Canadian mode l s It is possible to make use of either position. The display will automatically re m a i n in the language ch o s e n .
The date should never be ch a n ged manu a l ly between 9:00 P. M . and 3:00 A . M .a s this might affect the calendar mechanism and the accuracy of the date. ( Theme chanism will not be damaged if the crown is turned accidentally during this
time peri o d ,howeve r. )
Hope it helped U!
Anonymous
  • 1970 Answers
  • Posted on Jul 04, 2010
SOURCE: i'm tryng to set the date without changing the day
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
How do I set the day & date on my Timex Indiglo watch?
Google shows how.
https://www.leaf.tv/articles/how-to-set-the-date-for-a-timex-expedition-indiglo-watch/
?Quoting from the link above:
?"The Timex Expedition Indiglo wristwatch tells the time and date, illuminates at the press of a button, and can wake you up at a designated time. Once you receive and adjust your watch to your liking, you might have questions about how to program the date properly. You’ll want to have an accurate watch before wearing and relying on it throughout your day in class, at work or while exercising. You can set the date on your watch with a few simple steps.
Pull the plastic guard from beneath the crown knob (located on the right edge of the watch), and push the crown knob into the watch to start your watch. You will see the second hand begin to advance.
Pull the crown knob out to the middle position to set the day. The crown knob has three positions: “In,” “Middle” and “Out.” Turn the crown knob clockwise to advance the days up, until the current day appears in the window on the right side of the watch face. Turn the knob counterclockwise to move the date down in number. Push the crown knob all the way in to start the watch.
Pull the crown knob completely out, if the day doesn’t change with the knob in the middle position, and cycle the time backward or forward through 24-hour periods until you arrive at the current day. Push the knob in to start the watch.
Pull the crown out to the middle position and adjust your date to the next month for months that have less than 30 days. Your watch will cycle through 31 days every month, so manual adjustments for shorter months are required."
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 • Watches
7helpful
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 • Watches
2helpful
I can't figure out how to set the date.
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
2helpful
2answers
Day and date not synchronized with actual day and date
The watch does not have a "perpetual" clock so it does not know what month it is in. It will treat every month as a 31 day month, so you will have to re-set the date anytime a month is not 31 days.
If you appreciate me answering this for you then please rank this solution as "fixya" or at least "helpful" as what I have said will solve your problem. :-)
How to change day and date of fossil me1045
I bought my bf this watch for christmas... i set it before i gave it to him... it is the me1045
It took me forever to figure out how to set it, and even longer to actually set it.
The instructions fossil gives are useless, and the two side buttons do absolutely nothing.
So.. to set the day of the month, you have to spin the knob clockwise for 24 hrs for each day.
So, if it says 2nd, and the date is actually the 4th in the am, you have to spin it 4 times around the face, ie 48 hrs. If you go over, you're screwed and have to go all the way around again which, trust me, takes a really, really long time. Going counter-clockwise will not change the date, only the day.
The day of the week will change with the day of the month. Don't worry; they might not match up at the end. It may be the 4th and say it's monday. That's okay, because, unlike the day of the month, the week days can be turned backwards by turning the dial counter-clockwise.
Remember to take into account whether you are in the AM or PM. PM will require an extra turn beyond when it first switched to the date.
Goodluck; hope this helps.
Jan 04, 2009 • Watches
2helpful
2answers
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 • Watches
19helpful
3answers
How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
Nov 12, 2008 • Watches
Setting the date on a Guess G95290G
When you pull the dial out, you can pull it out into two different settings. One will allow you to set the clock/time. The other will allow you to set the date (the day of the month). It took me a while to figure this out as well, even witht he manual.
Aug 16, 2008 • Watches
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
