Canon imageRUNNER C2620 Color Copier Logo
Anonymous Posted on May 25, 2010
Image registration adjustment on canon imageRUNNER C2620
When i tried to print document part of the text on the document is clear and sharp but some of the text on the same document looks like the
registration has run out. what does the following adjustment got to do with the registration: LASER - pve-ofset
ADJ-XY - ADJ- X
-ADJ- Y
-ADJ- S
FEED ADJ- regist
-Adj-ref
-regist 2
CST -ADJ - MF A4R
-MFA6R
-MFA4
IMG-REG- MAG-H-K
Am asking this because am able to adjust the registratoin up and down but am failing to adjust the registration left to right can someone help me please?
Anonymous
Level 3:
  • Master 1,219 Answers
  • Posted on Jun 02, 2010
Anonymous
Master
Level 3:
Answers
1219
Questions
Helped
673768
Points
2880
Did you check the registration clutch? try to clean it. Be sure that the paper drawer sensor is "saying" the correct paper size.
Sir, my canon ir400 prints phots or pink colour paper very dark, the text print is ok, what should i adjust so it prints the photos and colour papers much clearly. plz help me sir. thank u
You can adjust it thru the settings it is like the menu, all is being adjust there including the color, contrast, bright etc.
It really depends on your need so the choice is yours, adjust it the way you want.
Printing colour quality problem on canon irc2620n laser printer
Are you service technician?
You can try to clean the laser unit, try to clear dc-con like on clc3200, but first try gradation adjustment.
If you not an technician do not try to clean laser by your self
3helpful
2answers
I have a Canon Image runner 1023. when I print i get the message load paper A4, change reg'd size, common settings. and the error light is flashing
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
1helpful
Canon imageRunner 3200n printing problem in color
ok you are in the right area are you taking the belt off to clean those rollers???? if not do that 1st. then you may have to clear the dc controller but 1st do a DPRINT under the service function menu. after the dccon clear you will need to put those #s back in
2answers
Color printing problem printing in double image looks there is registration problem irc3200 canon
this is allmost allways the transfer belt assy if you have over 200k on the machine the belt is slipping ever so little. you can take out the unit and remove the belt and clean all the rolles esp the largerer drive one. seen this many times
Printing problem on Canon IR3200
this is a common prob.. most of my users know wahat programs shift images and they adjust it accordingly... you may want to try some different drivers you may be using a pcl driver try a ps driver load accouple drivers up you can try the different ones go to imagerunner.com by the way if you have a print server on the back of the copier you should use the imagepass C1 or C2 driver
Canon imagerunner c3200 stuck in processing data
If you don't print via a server,you can turn the iRC3200 off...then back on and that will clear the print jobs.
If after doing this it STILL has a traffic jam in the print que when trying to print the same document then stop sending THAT particular document as the document has a formatting issue and NOT the printer.
If you DO use a print server then you(or your I.T Professional) need to go to the server and clear the print jobs from the server.
Print strange fonts even with pdf
is the font you are using a poscript font if not send as an image not text file
Same lines won't print
Sorry, but this is impossible, as a "printer problem". This is clearly a "software/buffer/document" problem.
This can ONLY happen (on two printers, same results) if the DOCUMENT has "exclusive" properties or instruction sets, or "invalid data" for the "missing" lines. For example, you may be printing an HTML document with "DO NOT CACHE" meta tag or java instructions about specific lines or form entries. Many sites (like banks, registration, or encrypted mail/login pages) do this as a security measure to prevent critical data from being inadvertently printed (and ending up outside in trash cans for an ID thief to pilfer). Other possibilities: The lines are NOT text data, they might be IMAGES of text, and saved in a format the printer/buffer does not support. Any of these examples would allow the software to DISPLAY the specific (missing) lines of text -yet NOT print them.
To test my theory (almost a certainty really), simply open the document and select PRINT SCREEN key (or use whatever key commands capture the screen as an image). This copies what YOU see, to the clipboard as a single "image" file (instead of a variety of ASCII characters, images, and code).
Next, open "PAINT" in accessories under MSlop (or any IMAGE editor like Photoshop, Gimp, etc)
Select NEW and agree to the screen size you are using (1024x768, 800x600, 1280x800, etc)
Select PASTE from file menu (or CTRL/V keys). Your document will now appear.
Print the document. The "missing lines" will now show up! If the document is too long for one screen shot, you may have to scroll down, recapture (PRINT SCREEN, etc) and paste one or more images into each other before printing it as a single IMAGE.
old marine
old marine
ZJ Limited
ZJ Limited
