We have a dynamode router and my laptoo detect its full signals but internet still doesnt work and we have to use the old wires despite spending money.can someone help me with this.thanku
if ur laptop detect full signal from ur router, click on the signal and let ur laptop connect to the signal..coz even ur laptop detect the signal,it doesnt auto connect,so u hve to connect it manually..
Are yo trying to connect to the wireless network on the laptop / If it is then make sure that the laptop is connected to the network. Click Here for more info on networking
The nework cable that came with the wireless router has RJ45 connectors (8 wire cable) and the telephone cable has narrower connectors RJ11 (4 wire cable) or RJ12 (6 wire cable - less commonly used).
I assume the Dynamode wireless router does not have a built-in modem and therefore needs to be connected to a broadband modem.
If broadband modem is a cable or DSL type, the broadband modem is connected to the Dynamode WAN/Internet socket with a RJ45 LAN cable.
If you have a broadband DSL modem you need a RJ11 phone cable to connect the moden to the phone socket.
You need to power cycle the network to syncronize the connection. You have to turn off the router and modem for 5 minutes and turn it back on. Make sure that the lights on the modem are steady before you trun on the router.
If you type in http://10.0.0.2 to the adress line on your web browser, you should see a login window for the router. I think it is the wrong address. I think you should first RESET the router. Look for a little hole about the size of a pencil point. Stick a paperclip in and hold it in for about 1 minute. This should reset the router to factory settings.
If you have the manual, it should tell you how to access its setup pages. This is a modem and router in one. You must have an ADSL phone connection to an ISP. You must have the ISP's information to connect to their network. This information is needed to set the modem part of the router to log onto the internet through the ISP. Best of luck.
To improve wireless signal from your wireless router you can try changing the wireless channel of it from the router setup page, set the wireless channel to the highest one so it will avoid interferences on your location........
PC > Connect to port 1 of the router Modem's Ethernet > Connect to router's Internet or WAN port
Then do a power cycle, unplug the power to the modem and router. Wait for 30 seconds then plug the modem first, wait for the lights to go solid, then power up the router. Your laptop should see the wireless signal now.
Cable modems and routers must be turned on in a specific way.
First, unplug both the router and modem. Next, plug the ethernet cable from the modem, into the cable router, and unplug the cable from the modem to the computer.
Next, turn on the modem, and wait for all of the lights to stay static (usually there's 4 lights, the main one we're interested in, is the status light).
Next, plug in and turn on your router.
You should now be able to access the router and configure it for your internet connection.
You haven't given enough detail for anyone to help. Reset the router to defaults and go through the setup process very carefully, paying close attention to the details. Don't set encryption until you have a good wireless connection.
