SOURCE: error message
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:487:0:0
select your proper vista operating system and then download it and install it sir.
SOURCE: Lexmark s 605 All in
Are you using internet explorer? that is an IE elated error not your printer. here are my possible solutions.
-Start Internet Explorer
-Click Internet Options on the Tools menu.
-Note If the Tools menu is not displayed, press ALT to display the Tools menu.
-Click the Advanced tab, and then browse to the Accelerated graphics section.
-Click to select the Use software rendering instead of GPU rendering check box.
-Click Apply, and then click OK.
-Close all open Internet Explorer windows, and then restart Internet Explorer.
OR
1.Open Internet Explorer
2.Click the Tools button, and then click Internet Options.
3.Click the Advanced tab, select the Disable script debugging (Internet Explorer) and Disable script debugging (Other) check boxes.
4.Clear the Display a notification about every script error check box, and then click OK.
Regards
SOURCE: Scanner won't work. Message error
mk:@MSITStore:C:\Program%20Files\Hewlett-Packard\Precisionscan%20Pro%203.1\gtf.chm::/vbscripts.txt
You may have encountered the following message while browsing certain websites:
"Internet Explorer cannot open the Internet site http://<website>.com. Operation aborted."
This really has nothing to do with your browser or your computer. You get this error because of faulty web coding from the webmaster's end.
IE displays this error when it is unable to open a particular element on a web page.
There are many things you can do to troubleshoot this kind of problem.
Upgrade Internet Explorer.
This problem does not occur in Internet Explorer 8. Navigate to Microsoft download Center and click on the "Download" button to upgrade to IE8 or IE9 (see Below).
http://download.cnet.com/windows-internet-explorer-8/3000-2356_4-10910662.html
IE 8
http://www.microsoft.com/windows/internet-explorer/default.aspx
IE 9
Click on "Tools" and select "Internet Options." Hit the "Advanced" tab.
Click to remove the check mark next to "Show friendly HTTP error messages" under "Browsing" sub-headings.
Click on "Apply" and hit "OK." Please note this works mostly for Internet Explorer 6, although there is no harm in trying this on older or newer versions.
Add the specific website that is producing "Operation aborted" error under "Restricted Sites."
Click on the "Security" tab under "Internet Options."
Single-click to highlight "Restricted Sites."
Hit on the "Sites" button and click on "Add."
Type the URL of the website and hit "OK."
This works for Internet Explorer 7, but again, you can try this in earlier versions.
Disable or require prompt for "Active Scripting" when you view the specific website.
Click on the "Security" tab.
Click to highlight 'Restricted Sites" zone.
Navigate down to the sub-heading "Scripting."
Click to select "Disabled" under "Active Scripting."
You may also choose "Prompt" if you want IE to issue a prompt when opening the specific web page or website.
You can run a free registry scan using utilities from http://re7.info
If you are still worried about the registry or need to fix any problems with it
Hope this helps.
