Formating code nokia x3-00
Off ur cell phone then keep press * and 3 and call(green) button then switch on your phone keep pressing the buttons then it will format
I have 1 nokia x3, the problem is, my unit will be turn off and restart itself even battery is full. Sometime, my unit also cant turn off. Need to remove the battery. I already restore to default by key-in*#7730# and pin, but looks like problem still same. Please help
rgds...Is
not open mobile
superb.. its working....!!!
my nokia x3-02 do no work...wat can i do that?
My nokia x3 touch do not work. when i open phone after 10 min touch do not work.
Görüntüleri açm?yor gösterilecek görüntü yok diyor
SOURCE: NEED TO UNLOCK NOKIA X3-00
u can get your mobile unlocked here
http://www.mobileunlocksolutions.com/nokia-x3/rs1wp9/
at very low cost..totally secure & safe..it gives you best solution..
SOURCE: i forgot my security code for my nokia x3-00
You can Unlock the Nokia From the Security Lock/Password Lock using the Master Reset Code,,,You can Check Master Reset Code for your Model mobile...at
http://www.prounlocking.com/unlocking-services/rs8wp6/
there You can get the Mater Reset Code at reliable cost..
I unlocked my Nokia 6030 From Security Lock there.
SOURCE: I want to add wifi
Hey!
If your phone has WiFi go to the Ovi store which you will be able to get apps from there!
Hope this helped!
1.
Switch off your Nokia phone.
2. Hold down the
following three keys, Green (call answer button) *
Key, and Number '3? key.
3. While holding these buttons, press the power button
and switch on the phone.
4. Wait for message
'Formatting' to appear on the screen and release all keys once you see
that message.
Method 2: Hard Format of Nokia Mobile Phone
1. Switch off your Nokia phone
2.
Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button
5. Wait for message
that message.
Method 3: Soft Reset of Nokia Mobile Phone
2.
Now Press following key sequence *#7780#
button and switch on the phone.
5. Wait for
message 'Formatting' to appear on the screen and release all keys once
you see that message.
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
1.
2. Hold down the
4. Wait for message
that message.
2.
5. Wait for message
that message.
2.
5. Wait for
i cant delete my call histories of ma nokia x3 phone ..
