I noticed a noisy spin cycle on our Duet washer, and upon investigation noticed pieces of like melted/worn plastic under the rubber gasket but around the washer tub. Is there any way to replace this part and can it be done by a home "handyman" such as myself? Am I right in thinking this may be the cause of excessive movement while the wash load is balancing itself out and causing the terrible knocking sound?
Sounds like you have abadrear bearing, not cost effective to repair by you, parts have a 5-10 yrs warr, you would need to check your manual, usuallt wind up replacing, the rear drum, inner basket, without warr theese parts are probalby 650 dollars. so i would call an authorized servicer(whirlpool wont send you parts even though they're warr)
We had a load come out with many bits of plastic in the washer. This clogged the drain.
