I saw you help resolve a blinking screen problem on a Sony tv. I have the same on 53" Sony Videoscope XBR TV. Can you let me know the solution you recommended?
Led will flash 5 times. Screen will blink. No matter what type of input. What is the fix? Led will flash 5 times. Screen will blink. No matter what type of input. What is the fix?
My led flashes 5 times then I loose the picture from anywhere 5 seconds to 45 minutes. Have no clue what to do. My led flashes 5 times then I loose the picture from anywhere 5 seconds to 45 minutes. Have no clue what to do.
AnonymousMar 26, 2014
TIMER LIGHT IS FLASHING CUTTING ON AND OFF. NO PICTURE BUT SOUND 53 INCH SONY VIDEOSCOPE TVTIMER LIGHT IS FLASHING CUTTING ON AND OFF. NO PICTURE BUT SOUND 53 INCH SONY VIDEOSCOPE TV
AnonymousMar 27, 2014
wont turn on red light blinks 1 timewont turn on red light blinks 1 time
You can't post conmments that contain an email address.
Just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
the model listed is a very old set---parts may not be available----language can be selected in the menu but the pink may be a adjustment of the screens (controls) or a circuit problem.
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Take care in solving the problem
hello well it's and old tv, my guess it could be capacitors in the power supply or even dry joints on the power supply board, it would be best to have someone with electronic experience to have a look at it
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
This is a convergence problem. Look in the back for a couple of large black ICs attached to a heatsnik. These should be marked STKxxx. These are the convergence ICs and either have bad connections or are defective. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. There may be other parts that need to be replaced as well. I'll look up your model to find the other parts to check. The convergence board as an assembly, I believe, is no longer available. The parts that you require are available.
you need to unlpug your set and reconnect everything over and see what it does.if that does not work have a tech check your system.your sony recviever is the culprit let that be checked.good luck
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Can you give me more info on this?
